0 Members and 191 Guests are viewing this topic.
ranuhook
This is my first post here. But in all honesty, I feel at home with this thread.
Concerning the design and loopback issue, can the eggheads here go and study this page, (figure 2) and see if it will solve same.
http://www.cheniere.org/techpapers/Final%20Secret%2013%20May%201994/index.html
Regards, Ay
bolt
Quote from: ranuhook on June 11, 2010, 10:41:24 AM
Regards, Ay
You SHOULD start a NEW thread to discuss other topics. This is about making and improving Kapanadze/Kapagen systems.
znel
[A author=bolt link=topic=7679.msg244631#msg244631 date=1276269877]
[/quote]
What a warm and friendly way to welcome a new poster... you simply have a way with words don't you bolt.....
It is an interesting way to possibly loop the output back into the system, I believe it is "on topic" as are all theories and ideas about the Kapanadze or how they may relate to the Kapanadze theory.   Thanks for sharing that link, I'll investigate it a little more....
retrod
Quote from: bolt on June 11, 2010, 10:27:44 AM
First always run a MOT with no secondary connections it should run cold and normal. This is to make sure your MOT is actually working properly.  It happens that the secondary windings burn out short in many scrapped MOTs!!
Are you using that microwave capacitor with your spark gap? Thats about 1.5uF and is fitted with quite a fast discharge bleed resistor and is pushing too much power through the spark gap. You need something like 0.01uf to 0.1uF rated 5Kv.  Also all the replicators will see MUCH reduced current if you fit a ballast using another MOT in series with this one and/OR small toroidal 240v 12 0 12 etc 50-100VA  in series with HT and spark gap. Short out secondary winding and wire across primary increases inductance.
Also add series and parallel motor run caps into supply i/p to correct power factor will half the current. These are things the replicators should be working on now to make vast improvements to this system.
I let things cool down a bit and left the transformer on with nothing connected on the secondary. I can't say it doesn't generate some heat with no load so it may be bad although I remember reading somewhere that they can produce some small heat with no load. I tried two 30uf AC rated caps in parallel on one input leg. I can get a 40w lamp to light, the arc is now violet. Somewhere in the testing my trusty Fluke 75 seems to have been damaged so I am now working blind. Oh, the large silver cap in the photo was not in the circuit, I used it as a connection point on one terminal. The white doorknob type cap is used as a filter it is rated at 40kv.
Thanks for the help.
ranuhook
Quote from: bolt on June 11, 2010, 11:24:37 AM
I believe I have not derail from the main KAP system discussion here, I am also interested in the KAP system working - the reason why I pointed to that site as an eye opener to those knowledgeable in the house.
Regards, Ay
