0 Members and 28 Guests are viewing this topic.
d3x0r
Quote from: verpies on November 14, 2013, 06:15:58 AM
Non-members cannot open this attachment.  Repost it here.
I did; it's attached on that message....
Yes... MO.  That is an important thing to have.  I'm trying to establish what mode the apparatus works in.
... like the mazzilli has several 'resonant' frequencies... at low voltage, it can be a very high frequency pulse, then after a threshold it generates higher voltage lower frequency osillations... (lower as in, on scope it goes from a solid bar/white noise signal to 2 waves... 100x dividier/multiplier )
then higher, my secondary load comes on; but at that point all power on the primary is pretty much gone... then increasing the voltage (and subsequently amps), the primary load comes back and secondary is strong...
re the hendershot.... the russian replication doesn't seem to have a sound component ...  http://www.youtube.com/watch?v=w3LRmSovEX8
Zeitmaschine
Quote from: captainkt on November 14, 2013, 04:27:24 AM
Now the question is where does all that energy go after pulling out red hot screwdriver
It depends what the watt meter shows. When the watt meter shows less energy consumed than the heat coming from the screwdriver suggests then something here is not in accordance with the known laws of physics. Otherwise the energy that the watt meter reads is perhaps converted to a magnetic field when the screwdriver is out. Anyway strange things are reported constantly when playing with induction hobs.
Hmmm ...
As no one here seems to have an advanced idea on this subject:
Quote from: verpies on November 13, 2013, 09:01:48 AM
Quote from: Zeitmaschine on November 13, 2013, 08:35:20 AM
The wire of a transformer's secondary coil is also »already conductive«. Nevertheless I can get current out of it when connecting both ends together.
That is different because in that case we have a time a time varying magnetic field that does work by pushing the charges away.
In your pot/cage system, the work was supposed to be done by the attraction of separated opposite charges coming together.
But we do have a time varying component: it is the closing and opening (electronically) of the Faraday cage that creates incoming waves of an otherwise static electric field.
Can we convert a static magnetic field into a varying magnetic field without the consumption of (much) energy? I don't think so, but maybe, who knows.
Can we convert a static electric field into a varying electric field without the consumption of (much) energy? Since contrary to a static magnetic field a static electric field can be shielded easily, therefore I think it is more likely that this could work.
On Kapanadze's table there is a metal box. By definition a box made of metal is a Faraday cage. No doubt about that. Kapanadze's box is always closed, that's for sure, no moving parts. The outside of that box is connected to a wire, also for sure. Most likely the wire on the outside is connected to the ground. What's left is the inside of that box. So what if the inside of that box is connected to something like a coil or a capacitor (resonant LC circuit)? Could this perhaps create a special physical effect that we have missed so far?
Wouldn't a Faraday cage with two connections, one at the inside and one at the outside (see below), be a nice novel electronic element? :D
Of course extern and intern pins are connected low-ohmic with each other. But this is also true for a coil. And no one would say, because of this, that a coil cannot have any effect on the circuit it is connected to. Could it be that due to the incoming electric field waves an apparent resistance (like in the wire of a coil) is created in the walls of the Faraday cage?
Hence more ideas are welcome what this new electronic part could do when connected properly to an electronic circuit.
P.S.: Since we don't know what an electric field actually is, then maybe it doesn't matter that we also don't know what a magnetic field actually is, does it? ::)
captainkt
@Zeit,Thanks for reply, I will continue with this the weekend to try to get measurements. The coils the way wired at the moment I had running for 30 mins all cool no screwdriver, then put screwdriver up tube got red heat, took out screwdriver let cool 30 secs then put back in get red again all whilst watching watt meter and bulb- got very little reaction about 0.05 watts  from 656.02  to 656.07. I am at the moment trying to convert output from hob to high current low volt (12) to make output useful as can only light bulbs and fire. I do always seem to get more out than in according to wattmeter but hard to tell just looking at fires and bulbs. Can easily light 20x 100 watt bulbs to what looks like full bright with wattmeter showing 1100 watts, went back to induction due to the fact that circuits are very lively and always work.Will play at this again the weekend.
Keith
verpies
Quote from: skywalker66 on November 14, 2013, 04:20:08 AM
Not entirely true... but further evidences was convenient denied. See here:
http://www.sinequanonthebook.com/AetherReinstate2.html
Michelson-Gale experiment from this article, simply measures the rotational speed of the Earth using the Sagnac Effect in a circular interferometer.
The Sagnac Effect in a circular loop can be understood as follows:
According to Special Relativity, the speed of light is independent of the speed of its source.
When the interferometer loop is rotating with the Earth, the emitter & detector also move with the Earth during the transit time of counter-propagating light beams. The backwards-propagating beam covers less distance than the forwards-propagating beam and arrives earlier at the moving detector. This creates a shift in the interference pattern. The shift of the interference fringes is thereby proportional to the angular velocity of the whole interferometer.  The axis of rotation does not have to be inside the enclosed loop area.
Fiber Optic Gyros function according to the same principle, and they can sense rotation regardless of the orientation of their axis (e.g. horizontal as well as vertical).
The circular relay of GPS radio signals around Earth is subject to the the same Sagnac Effect as well.
As you can see these experiments do not constitute evidence that space is filled with an all-pervading fluid that slows down light because it does not rotate with the Earth.
The space of our daily lives is just a reference system created by gravitating observers.
a.king21
Quote from: captainkt on November 14, 2013, 06:42:30 AM
Keith
Instead of a screwdriver, can you not insert a pick up coil?
