0 Members and 65 Guests are viewing this topic.
Hoppy
Quote from: Farmhand on November 15, 2013, 08:09:12 AM
It could be done in a few different ways, one way for example is induction through the table, he could simply turn on and off another transformer directly under the one on the board in time with the things he does above the board.
A King is dead right the guy is a fake , as soon as you hear his voice you should know it is a fake, he has already a few videos that are similar and if they were real he would be a millionaire, dead or lots of people would be doing it.
Hasn't anyone ever heard of magicians or illusionists. Anything can be faked.
Every single magic trick you see done by a magician is an illusion. They do it because they like to trick people.
Magicians do not impress me and never have. They are liars and fakes. If everyone ignored them they would go away or do something else for attention.
Cheers
Kapanadze is a master illusionist in my eyes and has already hoodwinked a few punters to his financial advantage, thus making him as pro at the game. He plays a team game and that's important when you are entertaining a group of spectators, especially when prospective investors are present amongst them.
Zeitmaschine
Here comes the illusion of anti-gravity. Or is it perhaps the real thing? ;D
Since Kapanadze's tin can is not levitating what else could it be in that round Faraday box that needs ionization?
Anyone tried yet to ionize a resonant 50Hz LC circuit?
Quote from: verpies on November 15, 2013, 02:25:24 PM
Quote from: Zeitmaschine on November 15, 2013, 01:20:00 PM
What else could be accelerated by ionization except air? Electrons perhaps?
All elements can be ionized.
Electrically accelerated can be: ions, electrons, protons, positrons, muons, charged dust, ping-pong balls, etc...
I think the load of the Kapanadze device needs electrons, a lot of them and very quickly. :D
Alik
Капанадзе использует принципиальную схему топливного Элемента, открытого типа, где катодная часть окружающая  среда (воздух, земля, везде где есть кислород)
Энергия берется из  дисбаланса энергий реакции разложения атомарного водорода и выделяющейся энергии при его рекомбинации, при условии что он дифундирован в металлическую решетку палладия, никеля, или бескислородной меди..., и добывается от туда высоковольтным разрядом..Правда металл через некоторое время выходит из строя..(поэтому Тариель интересовался запасами меди в Сакартвело).. Росси получает с этого тепло... Капанадзе сумел по мимо тепла получить электричество... используя принципиальную схему топливного элемента... Удивительно как два действующих самых прорывных девайсов нашего времени используют один и тот же эффект....
Внутри его катушек есть сердечники из бескислородной меди.. в которые запаяно вещество выделяющее Атомарный водород при нагреве...
Разогревает он его  индукционным способом через индуктор...
Индуктор и катушка съема должны быть из бескислородной меди... Земля должна быть очень близко.. провод заземления короткий...
Процесс накачки и сьема,  должен происходить в среде из Газа с водородной связью... и отсутствия кислорода...
Это основное Достижение Тариеля это изобретение такого протонопровода,  хоть и возникающего на доли секунды... процесс что-то вроде этого http://www.nanonewsnet.ru/news/2012/otkryt-novyi-metod-perenosa-protona
Alik
Kapanadze uses the concept of the fuel cell , open type, where the cathode part of the environment (air , land, wherever there is oxygen)
Energy is taken from the energy imbalance decomposition reaction of atomic hydrogen and the energy released when the recombination , with the proviso that it is diffusing into the metal lattice of palladium , nickel, or oxygen-free copper , ..., and produces a high voltage discharge from there .. However after a time the metal leaves failure .. ( so Tariel interested copper reserves in Sakartvelo ) .. Rossi gets with this heat ... Kapanadze was able to get the heat on by electricity ... Using the concept of a fuel cell ... It's amazing how two active devices the most progressive of our time using one and the same effect ....
Inside its coils have cores of oxygen-free copper .. which are soldered to the substance -releasing atomic hydrogen when heated ...
He warms his inductively through the inductor ...
Inductor coil and pickup must be made of oxygen-free copper ... Land should be very close .. ground wire short ...
The process of pumping and Flats rent , should occur in the environment of the Strip with a hydrogen bond ... and lack of oxygen ...
This is a major achievement of this invention such Tariel proton- though occurring in the fraction of a second ...process something like this http://www.nanonewsnet.ru/news/2012/otkryt-novyi-metod-perenosa-protona
Alik
Достижение Тариеля что он сумел обойтись без электролита, обеспечив эмиссию протонов внутри аквариума с искусственной средой...
источник протонов нагретая индукционным током  медная трубка (из бескислородной меди имеющая микропоры, ее отжигали и били молотком), с веществом при нагреве выделяющим водород...
Tariel achievement that he was able to dispense with the electrolyte, providing proton emission inside the aquarium with the built environment ...
proton source heated by induction current copper tube with a substance gives off hydrogen when heated ...
