0 Members and 66 Guests are viewing this topic.
Zeitmaschine
A soldering point for the brown and the red wire? :)
Heating-up a braid by soldering that contains an inner wire would be even more strange.
Quote from: stivep on November 16, 2013, 01:10:53 PM
It is hard to put the puzzle all together
there are to many variables.
Too many variables or too many wires? ::)
Then we should concentrate on that what we know for sure: We have (TK has)
1) a metal box (Faraday cage) the outside is grounded
2) with high voltage generated inside
3) input of that box is 220V/50Hz low amps
4) output of that box is 220V/50Hz high amps
5) the load is connected to a 50Hz resonant LC circuit and to ground
To me it seems there's not much left to miss. It could be the method of interconnection only that is still in question (to keep the »you'll laugh« statement valid). 8)
Just as a thought, if high voltage attracts electrons from ground (charging by induction) then maybe the trick is to get these electrons into the load circuit BUT NOT into the high voltage circuit (no sparking) because a connection to ground will kill the high voltage of course. The high voltage is only there to create a static field (within a Faraday cage).
Hoppy
Quote from: Zeitmaschine on November 18, 2013, 06:32:29 PM
Even stranger, is that a tubular braid is used for the earth conductor. In the case of the Aqua2 device, a long length of this is not cheap, so if he did have to purchase it, then it must have been important and presumably a length of ordinary wire or flat braid which is less expensive was not suitable. So, other than for the purpose of hiding an 'x' wire, why use hollow braid in preference to a much cheaper length of ordinary wire?  We do not see this braid being used on the green box or transparent box devices in the garden videos.
Alik
Появилась еще одна версия принципа работы Капагена "Ионная версия"
она основывается на следующих предпосылках и допущениях...
1) Такой большой ток в землю, её разрушение это следствие Ионной проводимости
2) Схема Сапога является подлинной
3) Принцип для всех устройств Тариеля Капанадзе один и тот же и он достаточно прост
его нужно постараться увидеть в двух механических устройствах и схеме "сапога"
4) Требуется синхронизация двух резонансных процессов
5) Необходимость в катодной меди обязательна и эти слова Тариеля не являются уводом в сторону
6) Замечание о том что Мельниченко Андрей близко подошел к процессу... но возможно
ему понадобится несколько лет чтобы внести небольшие изменения,- верное замечание
Первое на что я обратил внимание... и что заставило усомнится что процесс является
"чисто" водородным Условия при которых хранится предполагаемый Гидрид Бария BaH2
будь он даже "Соль барения) тоесть Оксидом бария BaO... он вот так запросто лежа на воздухе и нахватавшись
влаги
Cкорее стал бы Гидрооксидом Бария BaO + H2O = Ba(OH)2
Тоже примерно и получилось бы и с гидридом
ВаH2 + 2H2O = Ва(OH)2 + 2H2↑.
К тому же смесь еще хрен знает чего нахватала бы из воздуха
то есть скорее в девайсах "Механический" и даваесе "Диски" и "Сапоге"
мы имеем дело с насыщенным влагой Гидрооксидом бария Ва(OH)2 там же немного азота
и углекислого газа... Это скорее ЭЛЕКТРОЛИТ
И вот что я заметил... в двух девайсах "Механический" и "Сапог"
они образуют непосредственно с ферритом связку а если
допустить что в "Дисках Капанадзе" магнитный сепаратор
то и там тоже..
На видео с "Механическим девайсом" видно как какой то контакт бьет по белому веществу
а также есть контакт который немного с запозданием проходит
возле катушки (видимо требуется особая синхронизация процессов)
Что касается Мельниченко он отлично научился "ловить"
резонансы феррита... но догадаться что феррит нужно рассматривать
как "засохший" электролит да еще с магнитными свойствами
ему конечно было тяжело..
Но нечаянно могло получится у СР... когда у него кололись
ферриты и он на них пытался искрить...
PS..........
Надо отдать должное "Водородной версии"
она дала подсказку что мы имеем дело с ионами
которые можно катушкой разогнать...
на всякий случай "молитва СЕшника" вдруг в точку попал...)))))
Вся информация касательно установки распространяется по аналогии с лицензией GNU GPL.
"Это произведение является свободным программным обеспечением; вы можете распространять и/или изменять его в
соответствии с условиями GNU General Public License, опубликованной Free Software Foundation, версии 2 или более поздней.
Данное произведение распространяется в надежде на то, что оно будет полезным, но без какой-либо гарантии; в том числе, без
подразумеваемых гарантий товарной пригодности или пригодности для конкретных целей. Подробнее см. версию 2 и версию 3 условий
GNU General Public License. "
Только вместо "программным обеспечением" - читать устройство или модель.. Альберт Красов 19 ноября 2013 года
Возможно Оксид бария абсолютно сухой и тогда таким образом
закачиваются не ионы а Электроны, ведь оксид бария известный источник электронов
Alik
There was another version of the operating principle Kapagena "Ionic version "
it is based on the following premises and assumptions ...
1) Such a high current in the ground, it is a consequence of the destruction of the ionic conductivity
2 ) The scheme is genuine Boot
3) The principle for all devices Tariel Kapanadze one and the same , and it is quite easy
it is necessary to try to see in the two mechanical devices and circuits " boot"
4 ) It is required to synchronize the two resonant processes
5 ) The need for copper cathode is required and these are not the words of Tariel sidetrack
6 ) Note that that Andrei Melnichenko came close to the process ... but maybe
it will take several years to make small changes - the right note
The first thing I noticed ... and what made doubt that the process is
" clean" conditions under which hydrogen is stored alleged hydride Barium BaH2
even if he is "Salt Barenia ) ie barium oxide BaO ... it just like that lying on the air and picked up
moisture
Coming soon would Barium hydroxide BaO + H2O = Ba (OH) 2
And also about woulda and hydride
VaH2 + 2H2O = Ba (OH) 2 + 2H2 ↑.
Besides mixture is hell knows what would have picked up from the air
that is likely to devaysakh "Mechanical " and davaese " Wheels " and " Boots"
we are dealing with a water-saturated barium hydroxide, Ba (OH) 2 in the same little nitrogen
and carbon dioxide ... It's more of Electrolyte
And that's what I noticed ... in two devaysakh "Mechanical " and " Boots "
they form directly from a bunch of ferrite and if
admit that the "disc Kapanadze " magnetic separator
then and there too ..
The video with the " Mechanical devaysom " which can be seen as the contact has a white matter
and there is a contact that is a bit belatedly passes
near the coil (apparently requires a special process synchronization )
As for Melnichenko he learned to perfect "catch"
resonances ferrite ... but guess what ferrite should be considered
as " stale " the electrolyte even with magnetic properties
Of course it was hard ..
But could accidentally turn out at CP ... when he injected
ferrites on them and he was trying to spark ...
PS ..........
We must pay tribute to the " Hydrogen version "
she gave a hint that we are dealing with ions
that can disperse the coil ...
just in case " prayer SEshnika " suddenly came to a point ...)) )))
All information regarding the installation applies by analogy with the GNU GPL.
" This work is free software : you can redistribute it and / or modify it
Under the terms of GNU General Public License, published by Free Software Foundation, version 2 or later.
This work is distributed in the hope that it will be useful, but without warranty of any kind , including, without
implied warranties of merchantability or fitness for a particular purpose. For details, see the version 2 and version 3 of the conditions
Only instead of "software" - reading device or model .. Albert Krasov November 19, 2013
Perhaps barium oxide is completely dry and then so
not injected ions and electrons , because the barium oxide known source of electrons to try to dry and wet ...
Alik
попробовать надо и сухим и увлаженным...
[/quote]
