0 Members and 453 Guests are viewing this topic.
skywalker66
Quote from: stupify12 on November 16, 2013, 04:42:18 AM
@a.king21 I know you have seen the TK devices with your own eyes on operation. As I can see on the Green Box Video of TK I can see only 1 wire coming out of the box to the SPARK GAP and to the so called Tesla Coil Former? Am I correct that there is only 1 WIRE coming out from the Green Box Device?
There I see three wire coming out green box to the coil assembly. One wire thru spark gap probably going one end of heavy cooper coil, another wire (green one) to the other end of heavy cooper  and a white wire going to the one end of secondary coil, other secondary end connected to bulbs array.
How many Ground/Earth post TK utilize on his device? Does he need only 1 wire from the Ground connected to radiator or water pipe?
Just one black thick wire going on in the center of coil.
I really think his devices is simple but people like unnecessary complicate thinks in this regard.
gyulasun
Quote from: v8karlo on November 19, 2013, 06:59:56 PM
I made a mistake in the first schematic.
Input is direct current pulses.
Hi Karlo,
It is okay you inserted a diode in series with the HV line, but anyway you indicated the + and - signs at the HV source in the first pdf file too,  saying it is a DC HV source.  I assume a line output transformer with its built-in HV diodes is already a good candidate for the DC HV source (driving its input in a controlled fashion with pulse), this is just an example.
One more thing: in your post here http://www.overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg377502/#msg377502   the attached rar file has checksum error as per my WINRAR extractor so I can see it is a Multisim circuit simulator file but I do not have that simulator to open it should I be able to extract it.  Please when you have time make a picture file from the schematic in the Multisim.
Greetings,  Gyula
forest
v8karlo
Quote from: gyulasun on November 20, 2013, 04:06:43 AM
Hi Karlo,
Greetings,  Gyula
I am using TV flyback and adjust voltage just enough for spark to happen,
maybe 1000 - 1500V. I didnt tried insane voltages like 5000V or 10000V.
You can install trial version of MultiSim. It should open this file,
Site wont let me upload .ms12 extension so I rar it. Rar opens
on my laptop without any problems. I used WinRar.
After playing with this on my workbench I tried to make
simulation of this and it worked in simulator without problems.
So it was easyer to give you simulation than to explain in details
how it works.
Principle can be reduced to this:
Close input transistors and let the source energize the plates,
then open input transistor (cutoff source)
Close output transistor and collect current from all plates
Open output transistor and cutoff output
Repeat the process
a.king21
