0 Members and 192 Guests are viewing this topic.
v8karlo
Quote from: gyulasun on November 20, 2013, 05:05:42 PM
Hi Karlo,
Thanks for all this again, I have a RAR file extraction problem and cannot access the circuit simulation ms12 file in the RAR archive. I use WINRAR v5.0 and it reports checksum error.  I know this forum software has sometimes issues when downloading certain archives and possibly this is the problem in my case, (I recall reading other members here complaining when attempted downloading a file.)
Thanks,  Gyula
It happens with  ZIP too, I tried rar, zip ,ra, but all have same error.
So I opened gmail for you, go there and you will find my mail with MS file.
Everyone who wants to download the file can go to this mail and download the MSim file.
user: gyulasun@gmail.com
pass: freeenergy
Hoppy
Quote from: stivep on November 20, 2013, 06:05:08 PM
This wire was soldered to the braid.I also  looked very  carefully at the bolt side from the other side of the braid. No wire was going out.
http://www.youtube.com/watch?v=fBgDwG2ZLkM look at minute 9:24
        10:22
        12.30
The wire  bolted to the metal is shown at minute                       10:49
Wesley
Thanks for your reply Wesley.
Yes, there is clearly a soldered joint but this does not IMO preclude the likelihood of a thin hidden wire passing through the braid. This would be a ploy I would expect a magician to use in order to deceive his audience into thinking that in this case that there was only the single braided earth conductor.
The large cup washer over the crimp bolted to the iron work is suspicious in that it could easily hide a wire exiting from the shoulder of the crimp, which you could not have seen if the wire past through under the metal plate directly beneath the washer. We see a similar suspicious looking termination in the aqua2 video.
a.king21
Ming Cao analyses the Kapanadze coil and explains why an earth or a counterpoise is necessary.
http://www.free-energy-info.tuks.nl/
chapter 3 page 75
gyulasun
Quote from: v8karlo on November 21, 2013, 01:08:08 AM
pass: freeenergy
Hi Karlo,
Thanks for the file I downloaded it from gmail and managed to open it in Multisim.
In the schematic there is a signal generator connected between the MOSFET gates and you gave 220Vrms amplitude for this generator, frequency is 2 kHz. I do not get this 220V voltage value, this is not realistic, in practice the MOSFEts would burn out immediately. Why is this huge gate control voltage needed in the simulation? (signal generator goes to the gate of Q1 MOSFET and the other point of the generator goes to the commone gate pins of Q2 and Q3 MOSFETs, so generator is ground independent as shown).  The other AC source also has 220V amplitude given, driving the full wave diode bridge, and the positive output of this latter goes to a (voltage?) probe, labeled Probe2, this is the DC supply voltage of about 220-260V DC, depending on the load I suppose.
I ask how long the simulation would run because after 15 minutes it still has not finished? (so I stopped it) One more thing: what is the DC resistance of the built-in Heater component? (its Properties window does not include it?)
(I am not fully familiar with Multisim so this is mainly why I ask.
Could you share some more measured data (if you wish) on the breadboarded circuit as shown in the simulation?
Thanks, Gyula
Сергей В.
I HAVE POSTED ABOVE MESSAGE ON AMERICAN ENERGETICFORUM ALSO ON 3 DIFFERENT TOPICS.
ANY QUESTIONS ??  :D
