0 Members and 86 Guests are viewing this topic.
vrand
[A author=stephenafreter link=topic=7679.msg244652#msg244652 date=1276279316]
Theory behind it
Happy find !
I was guided to open the book from Eric Dollard "Condensed Intro to Tesla Transformers" and found the 3 coils circuit you are using in the KAPAGEN.
http://tesla3.com/images/forum/Dollard-Tesla-transformer-resonant-circuit-100_1476.jpg
Eric Dollard explains all the theory and the parameters to follow for best results.
A must buy here, 20 USD only : http://catalog.borderlands.com/index.php?act=viewProd&productId=37
I selected a few quotations from the booklet to give you hunger to order it !
http://tesla3.com/images/forum/Tesla%20Magnification%20Transformer.pdf
[/quote]
Eric Dollard also liked using Lutz Wire in his HF & HV Tesla Longintudinal Electricity Experiments.   ;D
Regards, Mike
vrand
Quote from: cell1 on June 11, 2010, 03:54:14 PM
Hi,
My impression is Tarie Kapanaze uses the coaxial cable. I see that when they show the sparkgap.
I found a book when is show how you can calculate the coil. There are some excel file to calculate directly the coils. I hope is useful.
http://dl.transfer.ro/Ultimate_Tesla_Design_Mitch_Tilbury-transfer_RO-11jun-70fcd5.A
Excuse me for bad English.
Best Regards,
Cell1.
Your English is good.   ;D
Yes, coaxial cable shielding would also help capture the HF radio interference.  Also, the wire insulation is thicker for HV power uses.
I was looking at the Kapanadze videos the different sizes and kind of wires he was using for both the coils and the ground connections.
Regards, Mike
romerouk
[ author=vrand link=topic=7679.msg244654#msg244654 date=1276281079]
Its working fine right now.   ;D
Could you please verify the idea that higher voltage = more extra energy theory:
- Would your 4mm & 10mm wire insulation hold up to your 12kV NST output vs the 2kV MOT output?
- Or, Kapagen needs the MOT Amperage more than the Voltage (MOT 2amp vs NST 0.03amp)?
Regards, Mike
[/quote]
I have tried to use NST 9kv getting low brightness then tried with NST 6kv with better results but not as using MOT.I am back using high voltage ac with 0.1uf in parallel with MOT, connected before the spark gap.All my high voltage diodes destroyed after experimenting different configurations.I have tried different coil types, combination of winding coil like Stefan suggested but nothing like the existing one... yet.
Something is special about the existing coil,I don't know what but so far it works best. Tomorrow I will make another identical one using one 10mm wire for the middle of the coil.
aether22
I have always thought that if I made a successful FE device I'd build another one and video the entire construction process so no one could complain about lacking details, if your coil is not so easily replicated maybe some indepth details on construction could be given.
retrod
Second attempt. After this mornings smoke test I almost gave up. Then there were some encouraging posts and advice. Here is some progress to report. I noticed on my set-up it works much better with high resistance loads. I started with two 40w light bulbs in series and then thought to try fluro tubes. I am up to six tubes in series with the two original 40w lamps. All the fluro tubes were removed from service a year or more ago as dim or non lighting. It reminds me of when many of us were adding LED's in series working with Dr. Stifflers SEC, what fun!
I have no way right now to measure input current. The voltage out of the variac is 90 volts. The spark has become very quiet with this load. I may post a short video on youtube later.
