0 Members and 341 Guests are viewing this topic.
Zeitmaschine
Experiments go on and also do the theories: If we have a LC circuit at resonance then there are electrons in the wire of that circuit oscillating back and forth. What would happen if we inject additional electrons into the wire of that circuit? Will these additional electrons move along with the electrons already in the wire? If so, will this result in a higher current going through the load (e.g. the headphone)? If not, then up to which point will the electrons move when they are on the way from the ground?
An ordinary antenna hanging in the air can generate voltage with respect to the ground thus it attracts electrons from ground, but not very much. Nevertheless this little voltage is the FREE ENERGY that powers a Crystal Radio, not the energy coming from the radio transmitter. When the antenna is replaced by a high voltage source then this should attract a lot more electrons from the ground. Therefore a good idea would be to do something useful with these electrons (like routing them through a load), so they do not come in vain. :)
The antenna of a radio is directly connected to the resonant LC circuit, hence the antenna stays always in resonance with the circuit. The high voltage is not directly connected to the resonant circuit (direct connection or sparking would kill the high voltage), hence a method is needed to keep automatic resonance between the high voltage source and the LC circuit.
Soon there are lots of empty Christmas cookie tins around to experiment with. A self-running cookie tin would surely be a nice gift ... ;D
Addendum:
TK - saying that in the spark gap interruption happens 50 times in one seconds. He is saying that in the spark gap is 50 Hz
Yes, in other words he is saying that the high voltage is modulated by 50Hz, as I see this.
pepsimaxzu
 ;D ;D ;D ,look at some eric p dollard lectures and you will stop saying shits.
Zeitmaschine
forest
Quote from: Hoppy on December 03, 2013, 06:24:15 AM
Your arrows are pointing in the wrong direction for bird shits.  ;D
Surprisingly, you are right!  ;D
