0 Members and 311 Guests are viewing this topic.
SeaMonkey
Discussions regarding "scalar waves" are
always interesting.
Has anyone yet given examples of how
scalar waves are produced in nature; what
conditions are necessary for their production,
if any?
Or, are we to believe that scalar waves are
exclusively man made?
We must conclude that scalar waves rely
upon electro-magnetics, at least in theory,
for their production.
I'm not convinced...
d3x0r
There are other dimensions that are not illustrated.  There is the frequency of length to twists... which can align the inner ripples more longitudinally or more laterally...
The slip of dense substance around the lip of the interface is allowed least resistance by a higher rotation.
Edit 1;
Watched that meyl summary conference and basically this is what he's saying... and the wave that's within the vortex is useful, but is not measurable.  We can measure the mass electrostatic and measure there is a mass electromagnetic, but we have no tool for the inside... unless there are end results.
THere is a mass flow resonance that AC works with.  The skin structure between the two is ... chaos probably.  There will be pinched off points, where bubbles of contained electrostatic in a magnetic will happen.  A high resonance will have this issue more as there's more chance for the tunnel walls to collapse and form a close loop between the electromagnetic.
So... there is a mass resonance for the gross flows; but there is also a resonance inside.  This is why even though I compute exact freqencies and capacitances and figure for parasitic etc I always have a badly formed inner helix.  I don't know how many waves around there are... there is usually at least one ripple where the pressure will push the walls of the vortex further (contract tighter from the outside?)...
{There is no gravity. The only force that exists is vaccuum.  No particle wants to be near any other particle, with a great force, such that in a homegenous (evenly spread) smoky air sort of state, the particles will want to be pushed together.  As a quantity of void is formed, that the force of vaccuum in the spaces between the particles is greater than between other nearer particles, pushing particles into packets of other particles and eventually forming huge masses. }
monopolar viewpoints are interesting, but probably there is an equal and interacting force.
So... if you have instead a mass flow of the outside system through, the interface between the two is of use?
Edit2:
50Ohm impedance :)  Working within an already 'flawed' system... or a preconceived conditions such that there is a balance of electrostatics in the chambers and a magnetic force in balance of a time to be able to shift the flow back and forth.... So really the issue is to drive it always forward (unless there is another application, as mazzillis work for induction heaters for low stress on the components) But this isn't impulse... or DC pulsed... so the system is basicaly in the same direction, can pulse the air (electrostatic) or run a magnet by it in sequence (electromagnetic) and keep the vortex going... and reinforced.
My Closed bottle system has flaws.  Without imparting a flow (moving a magnet next to the wire) the surface tension of thwa ter closes such that the weight of water on top is not enough pressure to overcome to up air pressure in the bottom... so I have to induce a swirl.... In a river/open system, this direction/feed to the system can be such to increase the flow (resonanate) so the effective power of that portion of the system is more than a lot of the consolidated input... but it is always the sum...
TheOldScientists shows this very well with his spark gap transmission circuit.
He builds a resonant tank, and demonstrates 'resonant grown' or VRSWR  very well.
He's not got negative resistance... the growth on that wave is real, but it's the same frequency as the input.  It's a demonstration of the beginning point of resonsance... mostly we have a stable resonance and miss out on the beginning....  When the voltage reaches the dielectric break of the spark gap, the gap opens and ALL current is dropped (as opposed to an LED threshold that also current limit the drop).  At which point he starts another cycle of growth from 0.  This is a combination of the resonance of the coil itself feeding back 80% and adding another small percent (why not total percent?)...
Edit 3:
(didnt' check if more had responded yet)
All of electronics in these coils etc happens OUTSIDE of the wire. ?  Oh I see... ya I got it, and I would say that as a statement.
1) The electromagnetic gross field happens outside of the electrostatic, andoutside of the wire (obviously, because you can sense it with a motor magnet).  the electrostatic is also outside of the wire... we can tell this when it reaches a high potentiall and you touch the wire, you get shocked.
2) There must also be something happening INSIDE the wire...
I had at one point pondered... is an electric flux an electron?  If you induce a current into a coil, and take that current off the other side, is it the same electrons ?  Or is is another (It's maybe something else) that just gets a motion imparted.
With the open mobius coil tests, this really leads me to beleive that an electron that moves transforms into the magnetic part, and is able to form somewhere else in a collapse (something like quantum field mechanics?)  So probably the answer is yes.. which is why you can't get more back than you put in...
But if both of these things happen outside, then it should be able to make a gross manipulation of their interface (the tunnel that's kinda hazy...)
But with the lighter/inner conduit open to the air on both sides (environment where elctrons di exist... or things that participate in electrostatics... )  and keep the magnetic on the other side....
So the wire is the eye of the tornado, most of the working space is really far removed from the wire...
(I lost the transition to this part) Otherwise grouping a lot of conductors in a bundle wouldn't get a good mass magnetic field...
Farmhand
I don't think there is much point arguing about scalars, I'm not here to waste anybodies time not even mine. I just like to give my opinion as others like to give theirs.
I see a scalar as a static set amount at a single point in space at a given moment. That's all it is, as I see it, a term to define that value. A scalar value. ie. at the point 3 feet above the center of a room the temperature is/was 25 degrees.
A wave is a different thing.
Does Meyl give a definition for what he calls a scalar wave ? What does it do ect ?
People can think what they like and how they like and believe who they want.
Acca
You all, might find this very interesting as I was following a researcher in the 1980's his name was Warren York, here is some more stuff to ponder, I am involved in this stuff and it's really scary to think that de-stabilization of matter can be done through scaler audio compression waves..... I really like your post.
"There are other dimensions that are not illustrated.  There is the frequency of length to twists... which can align the inner ripples more longitudinally or more laterally..."
I wll dig out a scalar clip and post it soon.. It has ripples and twists in a cold plasma tube...
Acca...
Audio Scaler Waves alter matter and make time bubbles..
In 1990 Mike Windell and Warren York began experimenting with modulating audio compression (scaler waves) into a cold beam plasma tube, and soon discovered that by placing a target in or near  plasma they could cause structural changes in various crystalline materials, they could harden or soften materials much like the Hutchison effect does by modulating the phase angle and duty cycle of the audio compression waves. "(this is also done by resonating a ferrite core in the TV yoke application as well as the ferrite tube, it's the very high audio frequency that ferrites generate that cause the scaler compression waves, in the Akula0083 power device TV yoke.)" Acca..
"We believe that many of the anomalous effects were due to time dilation. We have observed the apparent conversion of electrical energy in excess of what can be explained by conventional theory. It was also found that manyother strange and interesting effects could be produced"— Mike Windell
York describes a number of crystal energy anomalies that he encountered during experimental testing with Mike Windell, including a time-displacement effect that led to several hours of missing time, an array of materials-effects including the jellification of a large sample of quartz-crystal and documented molecular changes in Topaz crystals, and a strange occurrence during a power-failure when the cold-plasma beam continued to operate at full-power despite being connected to a blown circuit breaker.
York's research has extended Einstein's Theory of Relativity to include relativistic time-dilation on the electron-scale, which he describes in a Unified Field Theory containing a new model of the electron called the YGEM (York-Geier Electron Model), which he co-developed with associate Charlotte Geier.
Here is one of his scientific papers link below:
http://www.academia.edu/4166013/Quantum_Gravity_Pi_08_03_2013
Here is a example of the effect of audio scaler waves, his old document. VIP.
http://www.americanantigravity.com/files/articles/Cold-Plasma-Beam-2006.pdf
Warren York is the only person who used audio compression waves (scaler) non-magnitude form,  just a vector direction.
http://www.rense.com/general66/solid.htm
Link to Warren York, start clip at 19.35  on scaler waves  from 1980's this is where he later he did discover that scaler audio compression into a cold beam plasma would create stripped structure in that plasma and, he created a time expansion bubble that expanded and later he would alter matter..
http://www.youtube.com/watch?v=aa8vjmMnwPU
Here is the result of his experiments with his lab assistants and the shocking discovery.
http://www.youtube.com/playlist?list=PL0064E65614C9406F
Magnet clip of what a permanent magnetic field looks like, my old clip.
http://www.youtube.com/watch?v=wR7c4iXum-A
Link to the Italian Nuclear discovery that audio waves de-stabilize atoms...VIP
http://newnuclear.altervista.org/
Discovery and Exploitation of Ultrasound Nuclear Reactions using sound waves.
Below:
Farmhand
I'm not buying time dilation either. I try not to use the word time. The passing of events happens as it happens, time is based on cosmic motion in my opinion, we know time passes   and events unfold because as the Earth years go by we get older. When a person can live a lifetime before the Earth and sun make one revolution, a "year" I'll believe in time dilation. Or I see some other evidence of similar.
Ways of not using the word time are for eg. the period between tuesday and friday is two days.
Anyway go ahead and fill a few pages pushing Meyls theories. I won't be reading any of it but many will. I have already made my investigations into Meyl and I can do pretty much anything he can do with a set of transformers so what is the big deal.
