0 Members and 272 Guests are viewing this topic.
Zeitmaschine
Quote from: Grumage on November 28, 2013, 08:59:44 AM
Dear Zeitmaschine.
What if ??
Cheers Grum.
I'm still puzzled how to connect the high voltage synchronized with the 50Hz circuit to that 50Hz circuit.
What about that idea? Someone tried already? It looks somewhat similar to this circuit and -of course- to a crystal radio.
One plate of high voltage capacitor C1 is connected to the high voltage (modulated by 50Hz) so the second plate of that capacitor should attract electrons from ground through the 50Hz load circuit and with a little bit of luck boosting the amps circulating through the load connected to that resonant LC circuit. :)
Hoppy
Quote from: stivep on December 18, 2013, 08:11:13 PM
http://www.youtube.com/watch?v=UPJPPZLhsqY&feature=youtu.be
Wesley
Wesley,
Best wishes for the New Year to you and thanks again for your excellent translations on the Akula videos. I'm pleased that you picked up on the anomalous, almost zero reading analogue meter in Akula's latest video. I'm hoping that 2014 brings a greater realisation about the importance of appropriate measurements when experimenting with devices claimed to be OU.
Hoppy
stivep
Quote from: Zeitmaschine on December 18, 2013, 08:20:25 PM
quick:
I will think about it later little more.
Parallel resonant circuit is not allowing  for one frequency only ( one frequency bandwith that means all of frequencies in very narrow region)
to go-thru    or more grammatically  to pass-through.
So all other frequencies are flowing with no problem
But if you use  parallel resonant circuit as connected  with respect to the ground here we  have interesting  phenomenon,
all of the frequencies from  the top of parallel circuit that is connected at bottom to the ground will be shorted to the ground  and only the frequency that is not allowed to pass- through  is the one that has "immunity" with respect to the ground.
Series  resonant circuit is opposite in nature  -
it allows only one frequency to go-thru an all others are excluded
But if you use series resonant circuit as connected with respect to the ground  here we have interesting phenomenon,
all of the  frequencies from the top of series circuit  that is connected at bottom to the ground will not be shorted to the ground and only one frequency (one frequency bandwith)
  is  allowed to pass- through  an that one  has  no "immunity" with respect to the ground.It will be shorted to the ground.
So if you  have antenna of radio receiver and you connect it with series resonant circuit that particular frequency is shorted to ground all others will be able to go to  detector or HF amplifier.
that can  have application if that one frequency is frequency of local noise interference of your radio receiver .
And if you  have antenna of radio receiver and you connect it with parallel  resonant circuit all of the  frequencies are  shorted to ground and only the one that is in frequency of resonance of parallel  resonant circuit , will be able to go to  detector or HF amplifier.- another words will not be shorted to the ground.
that can  have application if that one frequency is not  the frequency of local noise interference of your radio receiver  but is your frequency of choice.
Back to Basics: Tutorial on LC Resonant Circuits
http://www.youtube.com/watch?v=hqhV50852jA
THINK ABOUT IT
think about  phase angle when analyzing dependency of  earth pump where electrons are being sucked from the  ground to balance force  from the top
of "capacitor"( capacitive reactance)
The secret is in force and mechanism of applying force
example: suck the water from the say plastic hole with your mouth , and than it flows by itself
think about it my friend
I'm in Colman and I will do everything to finish my work
But that  does not mean that I'm not into other forms of FE.
My wish for New Year is to see all of the oil/ energy barons  being affected by Free Energy big............... the biggest  time ever.
Wesley
The item  right below  has hydraulic cover pump as its cover might be   heavy as impossible (to be moved by hand)
I  collect all  required tools  for Colman...................... it would not be me if I invest in dream only........ it must be something in it :) ( big smile)
d3x0r
http://spectrum.ieee.org/tech-talk/semiconductors/design/twisted-light-sends-data-through-optical-fiber-for-first-time they did it in air previously
Researchers have successfully used light to transfer data through fiber optics cables. By using twisted light, they were able to transfer 1.6 terabits per second.
Twisting light means photons have a quantum characteristic called orbital angular momentum (OAM). Photons with OAM have electric and magnetic fields that corkscrew rather than oscillate in a plane. There are a theoretically infinite number of OAM values, and multiple beams having different orbital angular momentums can occupy the same fiber, allowing  more data to be transferred.
Twisted light technology isn't only for optical wavelengths. Researchers in Italy and Sweden were successful in applying OAM to radio waves. They were able to transmit two "twisted" radio beams a distance of 442 meters by bending a dish antenna. But some radio communication scientists aren't convinced that this will actually increase capacity. Some argue that OAM radio frequencies mimic existing multiple input multiple output (MIMO) technologies.
http://en.wikipedia.org/wiki/Orbital_angular_momentum_multiplexing
http://en.wikipedia.org/wiki/MIMO
http://en.wikipedia.org/wiki/Optical_vortex
"At radio frequencies it is trivial to produce a (non optical) vortex. Simply arrange a half wavelength diameter ring of antennas such that the phase shift of the broadcast antennas varies an integral multiple of 2[/size]π[/size] around the ring."[/size]
Zeitmaschine
Quote from: stivep on December 19, 2013, 11:38:43 AM
Isn't the high voltage input of C1 in essence the same like receiving a radio signal? The radio wave coming from the AM radio transmitter is a high frequency wave modulated by an audio signal. Medium wave is 535kHz to 1705kHz, the modulating signal is audio frequency up to 8KHz.
Here the high voltage frequency is around 100KHz (up to 300KHz), its modulation frequency is 50Hz. So if a crystal radio can boost the energy coming from the radio transmitter, then it should be possible to boost also the energy coming from the high voltage generator.
Also worth a try: C1 in 50Hz resonance with L1 and C2 in 100KHz resonance with L1.
And I think, so far this is as close as we can get to the principle of work of the (simple-to-laugh) Tariel Kapanadze device. Just the working replication is still missing.
