0 Members and 142 Guests are viewing this topic.
Hoppy
Quote from: verpies on December 21, 2013, 05:55:11 PM
Thank you for your effort in translating these videos for Russian non-speakers.
This series of videos is remarkably open compared to Akula videos.
Vasmus does not hide details on purpose and he makes a conscious effort to expose all external connections to the device ("x wires").  This is a refreshing attitude in itself.
Yes, a much improved demonstration over any other I have seen, which IMO pins down the 'x' wire to the earth lead, which I suspect is not actually earthed! Also why hide the light bulbs in their packaging; is there something to hide here, like they are not actually each 60W rated?
verpies
Quote from: Hoppy on December 21, 2013, 06:31:52 PM
Actually, I am quite familiar with the reason for hiding the bulbs in their cardboard boxes.
When I was helping my friend on another continent to make his RV inverter (not a FE device), I had to cover my bulbs like that so they did not blind my video camera.
If I did not cover my bulbs, he could not view my videos and understand them due to oversaturation of the camera's CCD and the action of its automatic aperture in exposure control.
stivep
cheappower2012
Hoopy
Heres is a possible way to fake it,I don't buy its real,I also don't believe sharkheads device works  either.
The ac detect relay comes on.when ac is applied across the hot and ground,but doesn't start
lighting the lamps untill
the start relay gets the 9 volts which then starts the whole thing,the power supply causes
the start relay to latch,untill the ground switch disconnects the the ac.When the ac goes the ac detect relay opens
no power is applied to the lamps they go out however  because theres still charge in the capacitors  the rf lights the CFL
for a short time untill the capacitors discharge.It may require some rf coupling or decoupling however the basic form should work.
Hoppy
Quote from: cheappower2012 on December 21, 2013, 10:00:49 PM
Hoopy
Yes, agreed. Having gone through the two videos, I do not see a good shot at the broom head, so this is the most likely method of faking. Its also strange that in the first video the guy lines the lamps up along the edge of the carpet, strongly suggesting that the 'X'-wire is under the carpet.
I think the starting mode of operation you describe is very close to that adopted by Kapanadze for his devices started with a 9V battery.
@ verpies
Good explanation as to why the lamps are shielded.
