0 Members and 43 Guests are viewing this topic.
forest
 :-\  You are very dissapointing  :-[  - always look for hole instead for real value... everything could be faked , why to fill thread with such accusation without the method of prove ? Just ask and pass question to inventor and he will show you the proof !
Hoppy
Quote from: forest on December 22, 2013, 09:09:52 AM
Sorry to disappoint but I see no real value in any video claiming a self-running device that could so obviously be faked like this one. I give the guy credit for showing a lot more detail of his setup than others that I've seen but he leaves out close-up camera shots of the very area that the 'x' wire is most likely to be detected. Coupled to that, his first video shows a line of lamps along a carpet edge and immediately gets calls to up his game and set out the lamps in a less suspicious way! How can anyone seriously take this device as a self-running contender.  :( Of course anything can be faked on video but in order to get my serious attention, a lot more attention to detail is needed and most importantly, full technical and build details details to allow others to have a decent chance of replication. Lets wait and see if he can present his device in a more believable way and open source full tech and build details.
Zeitmaschine
What about the principle of work? I do like one-man free energy videos, in which that one man can't explain the principle of work of his own device he is presenting. ::)
A principle like that perhaps: »I have simply found a resonance and a method, which automatically adjusts a resonance between primary and secondary coils.«
So when we have a fixed 50Hz current and we want to keep resonance in a LC circuit connected to that 50Hz frequency then we have to adjust constantly the value of L and/or C in the resonant circuit in order to keep resonance with that 50Hz frequency. That is very impractical because even slight changes in temperature or load resistance will detune the resonance.
But what if the resonant LC circuit itself creates the (50Hz) frequency of the input current it resonates with? Actually we then should have always resonance independent of the value of the true frequency. This method is favorable in case not the frequency matters (like with radio broadcasting) but the pure resonance as such.
Now, secondary coil = L of the resonant circuit, primary coil = a high voltage source (?)
forest
Zeitmaschine
Well, I think the principle is stunning but very hard to explain or even harder to prove especially when somebody is not backed  by scientific knowledge and lab team support...Nature works in duality not singularity...Energy is never created or destroyed but we were taught that it is converted into other form and that it require work to be done. However what is "work to be done" ?
