Acca
Here is the latest Russian forum translated posts by Akula0083 below and an extra diagram.
http://translate.google.com/translate?sl=auto&tl=en&js=n&prev=_t&hl=en&ie=UTF-8&u=http%3A%2F%2Frealstrannik.ru%2Fforum%2F48-temy-freeenergylt-antanasa%2F134551-akula0083-obshhaya-tema-1.html%3Fstart%3D1116&act=url
Also there is the Brovin patent (below link) (Ketcher) and the Very hard to find waveforms from that patent as described in the latest
videos by Wesley.
http://www.findpatent.ru/patent/244/2444124.html[/font]
http://www.youtube.com/watch?v=HHc4kqVgWGU[/font]
[/font]
Here is a patent that has Tesla flat coils in it's application... VIP !!
https://docs.google.com/viewer?url=patentimages.storage.googleapis.com/pdfs/US7973296.pdf
a.king21
ElementSix: Thanks for the info.
I too am working with Tesla switching methods.
100 years later and they are still the best.
Look at the ignition patent 1896. It will help you.
Read what Tesla says about discharge from circuit of high self induction
into a circuit of low self induction.
In another patent Tesla's smart enough to use an electric motor as part
of both the switching and inductive loop. The benefit is that if
the motor stops you don't get a short because the inductive loop moves the Tesla switch
on. (Ozone patent).
I use it and it works.
Zeitmaschine
Convert Static Voltage to Any Amount of Electrical Power Required
Program I will be the conversion of a static voltage (available world wide) from a simple static source to furnish (freely) any amount of electrical power desired. It is simple and very cheap to provide a static voltage source—indeed, one may take the necessary "source static voltage" directly from the earth-electrosphere vertical voltage gradient anywhere and everywhere on Earth. This "charged earth-to-electrosphere" voltage gradient averages about 300,000 volts {64}. When standing, its voltage difference between one's head and one's foot may thus reach about 250 volts or even more.
As a "source" for the proper asymmetric circuit or system, a static voltage can be made to potentialize the charges in a briefly-connected external circuit (or a great number of them) without drawing current.
The freely-potentialized external circuit can then be disconnected from the source (with circuit charges still pinned and zero current), and its gap recompleted (as, e.g., by adding a diode and a resistor in series, with the diode oriented in the "current pumped around the loop" direction). This makes the freely potentialized external circuit complete again, but as a separate system entirely separated from the original static voltage source.
Once the separated external circuit is recompleted, its charges are allowed to come unpinned and current will flow in it, powering the load while the freely-potentialized circuit dissipates its potential energy. Then the process is iterated; the gap is re-opened and the static source is reconnected with the charges again pinned, to again freely potentialize the external circuit.
So one potentializes freely and statically with original source connected, and then dissipates the collected excess potential energy dynamically and separately from the original source.
In this manner the static voltage source will iteratively furnish all the electrical power in a specific circuit that one wishes, literally without limit, and without having to do work just to continue having the source. If one uses only voltage input from the static voltage source to one's external circuit, then no change in the source's static voltage occurs, because no current flows from or through it, and hence no electrical power is drawn from it or used to destroy it.
Use of a static voltage source in this current-free fashion is beyond simply repeating the WW II use of the known difference of potential (between a jungle treetop and the earth's surface) to draw sufficient power (both current and voltage) to power a small radio in the South Pacific. There the troops used only the standard symmetric EM circuit, which has to draw power (both voltage and current) from the earth-electrosphere voltage difference source utilized and thus has to do work in getting the radios powered.
The overall power that can be drawn directly from a segment of the static earth-electrosphere capacitor's voltage and charge is very small, but if one draws only voltage (with dq/dt = 0) and uses the proper asymmetric circuitry to collect and flow (shuttle) that voltage onto pinned charges q in a collecting circuit, then one can take and use just the voltage. Using this free static voltage to potentialize the external circuit will produce the desired amount of free potential energy W in the asymmetric collecting system (on those pinned charges q) that one requires, by the simple equation W = Vq. If we do not allow any current from the external circuit and load to flow back through the dipolar voltage source, then all we continually need from the source is the voltage V itself. That can and will be sustained indefinitely by the source. Freely! Forever!
"Static voltage" is actually a dynamic set of ongoing bidirectional EM energy flows (longitudinal waves), as rigorously shown by Whittaker in 1903 {65}. Hence so-called "static" voltage will indeed flow (without doing work) onto a "statically connected" collection circuit containing pinned charges q, "potentializing" that receiving circuit so that stored potential energy W = Vq appears in it.
This "statically potentialized" (excited) collection circuit is then separated from the static voltage source. The gap left by the disconnected primary static source is recompleted (say, by a resistor and diode in series across the gap) as a separate external circuit and system, and then this separated circuit's freely collected EM potential energy is dissipated in its loads to power them. This results in delivering a fixed amount of free power to the loads to power them, completely independently of the primary static source (the electrosphere, in this example) {66}. Any convenient and very cheap static voltage source can be substituted.
This type of asymmetric system and circuitry is a part of the Heaviside model equations that Lorentz {59} deliberately discarded in 1892 by arbitrarily symmetrizing the equations for the specific purpose of eliminating all such systems, insuring that electrical engineers build only COP<1.0 power systems insofar as taking the energy from the local vacuum potential is concerned. Since then, EEs have always built and used only symmetrized power systems, thus directly generating the world's present energy crisis.
Rapid and Decisive Solution of the World Energy Crisis
d3x0r
Quote from: Zeitmaschine on December 28, 2013, 03:11:11 PM
Two things;
1) Lasersaber has an electrostatic engine that he can run from a kite...
(and prior videos)
http://www.youtube.com/watch?v=oMK0dEKWJdY
2) igor muniz just posted a 'long runner'
http://www.youtube.com/watch?v=YPiUSCQIKC4
Built it in a sim... works pretty interesting; not sure if I really grasp it but...
Longrunner model
to start; reset, close the ground switch, close the power switch, open the ground switch, open the power switch.  Output is in the center in watts.... it's got a long wind down.  I added ressitances; {Without resistance, the parts beheave as their ideal part, so if one needs a complete model, addtional parts need to be added for the characteristics... otherwise, without resistance, something like 18KW was the input.... for lots of pulses of 18W.... added a loss resistor in circuit, which helps stabilize it)
... basically if it was given a impulse of high voltage it would run a long time....
elementSix
Its a static energy for sure.  Think of running a cloth down a plastic pipe for a static charge.  Except you are using a combined positive and negative energy together, running a single impulse down a copper wire with resistance and diode to keep it from spreading out and ruining the static formation.  I would use HV pots to adjust the rise and tail of the impulse.  That could help the output. Steven Mark used bailing wire on one of his 4" TPU's.  I wounder if the resistance and magnetism of the steal wire can magnify the output?...hint hint?   or maybe he just used it to hold it together, which would be dumb.  If you run this lightning energy into a bank of batteries and use a converter, you could have no problems running cpu's and tv's.  The batteries might help change that static energy into useable for our tech. society.  I did an experiment using two wall transformers with a bridge rect. off one and run it thru a cap and connected one side directly to the other transformer and ran the other side thru a few neo magnets that i stacked so as to quench the spark gap.  Without the neo's I couldn't hope to create a spark gap but with them I could hold the wire at certain areas one the magnets and get a large ball of sparks and by holding it at different distances from the magnets I could get more out than in.  I had the second transformer running to at antenna and the other thru a cap. with one side to ground.  I would touch the ant. and the ground with my arm and run the wire to certain parts of the neos and I would get a large electrocution from the ground wire and ant. wires.  Its very primitive I know but I was just messing around.  The input was 12V from rectifier.  Which I could never get a shock from.  I didnt measure anything, cause I was just trying different magnets for use with a spark quenching.  It is the basic same thing that magnacoaster does.
I was thinking of what akula used for his newer device.  I think Wesley said he used one transistor.  What if he used a square wave to drive that on and off, like 10 or 20 time a second.  would it be that easy.  10Hz driving his device but not ac, just make and breaks with the positive on constantly with the diodes and resister and spark gap between them.  Any thoughts that is what he is doing.
