0 Members and 137 Guests are viewing this topic.
captainkt
@Hoppy, maybe it was all he had handy to use with out being important, Tarial does not seem to spend money on special equipment or materials.
Keith
NickZ
  Probably because TK does not make any of the devices that he has shown. As he does not even have a soldering iron in his bedroom, or any other electronic test equipment.
  A detective to follow him like a.king suggested would be needed.
  I attached a short piece of copper braid (2 inches long) to my Mazilli circuit input and found that it heats up instantly to where one can't even touch it.  So, I don't see how this is going to help to keep the Fets from going up in smoke. Maybe Hoppy or one of the other guys can try this out also.
  My Mazilli/GeoFussion round core crt can light three bulbs, but the transistor get very hot, even with a small pc fan on it. I think that it would burn up on 24 to 36 volts.
  I'll continue tuning and testing today.
Hoppy
Quote from: captainkt on January 04, 2014, 10:34:20 AM
Keith
Hi Captain,
I recall way back on this thread somewhere (I think a.king21 mentioned it) that TK could not complete the Aqua 2 device without out-sourcing some co-ax, as he did not have suitable cable to hand. I assumed this was for his coils but I later thought that it was more likely also needed it for his earth wire, as it would have been far easier to use a length of ordinary wire for the connection to earth. Its of course possible that he could have had a long length of tubular braid to hand for the earth conductor but its more likely IMO that the tubular braid we see used as an 'earth wire' was out-sourced, either using the stripped braided screen from co-ax cable, or that he also obtained a length of tubular earthing braid. As I have stated before, I think it most likely that the tubular braid was important and needed to hide a 'hot X wire'.
Hoppy
Quote from: NickZ on January 04, 2014, 11:22:40 AM
Hi Nick,
Good to hear that you are up and running with your new mosfets.
Check the on-load voltage of your battery whilst lighting the three bulbs. If the voltage drops low, then the mosfets will not have sufficient voltage at their gates to switch without producing a lot of heat. You will probably find that a higher capacity battery, like used by Geo will serve you better.
The copper braid may have insufficient cross sectional area to handle the current drawn. You will be looking at around 8 Amps plus per 100W of load at 12V. My Mazillii can draw as much as 23A on a 200W lamp load at 11V!
drodenbe
Hi every one,  I guess out of total disgust with my self and what I have been able to accomplish in free energy over the past 6 years of some 500 to 600 various size, shapes, and length coils.  Some 20 - 30 thousand feet of various size wire. Motors of different shapes and sizes and a basement full of very pretty but worthless projects and designs.  I have not much to show.  I am sure there are many others in the same state of mind and where I am at.  Even though this will pass and I will find myself winding that next coil that may be the one! I feel like a alchemist looking to turn lead into Gold!  So  all that being said.  I want to share some humor to help shake off this funk I am in.  So here is my solution and working schematic of a free energy device that I believe is just as valid as all the other so called schematics out there claiming this is the one that works because I saw it on youtube and it has to be true and right!  So study closely my attachment and if you don't smile just once,  you need a break from your research as I did.  Thanks and have a great year.  Be assured if and when I find something I will show all and share every aspect of my findings.  Good Day! :)
