0 Members and 70 Guests are viewing this topic.
Zeitmaschine
Quote from: verpies on January 02, 2014, 06:56:27 PM
That's obvious - both need to be asymmetric.
The wind is more interesting to discuss than a pinwheel.
That means, without an asymmetrical component in the FE circuit we will get nothing - even if the ambient energy would be asymmetrical.
Quote from: Grumage on January 04, 2014, 04:07:41 PM
Here is the rather hurried schematic !! :)
How many ground connections?
magpwr
Quote from: captainkt on January 04, 2014, 05:34:18 PM
@Hoppy, one of the reasons I do not think Tarial fakes the way you suggest is that on one of his 2004 bedroom vids he feeds with inverter then at end of demo just pulls out the power plug between the device and inverter and the bulbs slowly fade. He makes no other disconnection to stop it working, this way of stopping I have not seen before and it looks very very convincing to me.Also to feed grid power and then mix with inverter power is not possible, i have blown dozens of inverters by just a one second cross over.
Keith
hi captainkt,
An inverter should not be connected to the grid\main power at all.It was not design for that.
Instead a Grid-Tie inverter (preferably sine-wave) should be used which support wide  input voltage range eg:10.8v...28volts .
These are design for solar cells where output voltage changes throughout the day provided if there is sufficient sun.
I have previously uploaded a simple video in youtube to demonstrate -1000watt Pure sinewave Grid Tie Inverter
http://www.youtube.com/watch?v=mtm17CtTpaY
magpwr
Quote from: drodenbe on January 04, 2014, 02:08:48 PM
Hi every one,  I guess out of total disgust with my self and what I have been able to accomplish in free energy over the past 6 years of some 500 to 600 various size, shapes, and length coils.  Some 20 - 30 thousand feet of various size wire. Motors of different shapes and sizes and a basement full of very pretty but worthless projects and designs.  I have not much to show.  I am sure there are many others in the same state of mind and where I am at.  Even though this will pass and I will find myself winding that next coil that may be the one! I feel like a alchemist looking to turn lead into Gold!  So  all that being said.  I want to share some humor to help shake off this funk I am in.  So here is my solution and working schematic of a free energy device that I believe is just as valid as all the other so called schematics out there claiming this is the one that works because I saw it on youtube and it has to be true and right!  So study closely my attachment and if you don't smile just once,  you need a break from your research as I did.  Thanks and have a great year.  Be assured if and when I find something I will show all and share every aspect of my findings.  Good Day! :)
hi drondenbe,
I'm sorry i choose to run away from your circuit as far away as i can since it needs "Holy water" for the ground. 8)
I have attached the circuit as provided by you.At least we all know whom you are and what you are capable of.
I do "fear" for the worst if Hoppy and rest of us would even have the spare time to comment on your circuit at all.
drodenbe
Magpwr.
I am glad you found the humor in the circuit.  I ran across this a while ago and as I was searching for a circuit I wanted to retry I found this again and wanted to share.  It brought a smile as I looked at it and wondered that may be I could run a wire to the sun and make it work! LOL!
I have been following this link almost from the beginning but have not posted much.  I have had some successes with the joule thief,  a couple three phase motors I designed and have worked on the kapanadze for so long and made so many different coils that it is almost a blur.  Best I was ever able to get was 300 watts, no self runner.  I did run across a translation  of a katcher circuit that I had some success with earlier last year but until this latest translation did not realize that the coil is bifilar and not a single layer tesla coil.  So I am winding that next coil to check it out.
As I said earlier if I find something that works I will be glad to share all that I have and not let every body spend the next year or so trying to figure what was done.  No hidden wires or batteries.  That kind of stuff really tics me off!
Have a great day and hope one of us out there finds the Rosita Stone!  :)
Hoppy
Keith
Captain,
I agree that the inverter is not supplying the load in any way. Do you think it possible that the lamp load is being supplied by a remotely sited petrol / diesel generator that has some type of load sensing switch?
