0 Members and 70 Guests are viewing this topic.
Grumage
Quote from: captainkt on January 07, 2014, 08:53:49 AM
@a.king21, Why is Brazil supply any different to UK? In the UK it is called PME neutral and earth are bonded at meter and the mains cable in to house has just a single solid red wire up centre of stranded earth /neutral I cannot see how any power can be obtained I have tried. One weekend my earth leakage trip failed and I once ran my house with just earth rod and did not use the neutral for a month (could not get suitable replacement trip) but no gain, Meter still turns same rate even if you use just the live in to the house. Measure potential between earth and neutral nothing at all.
Keith
Dear Keith.
Our member aKing21 is referring to the HV transmission system not the LV one. Here in the UK we have a two wire HV feed to supply single phase pole transformers (Overhead Line). Apparently in other parts of the world they just use a single HV wire and pass that through the HV to LV transformer to the ground for the return path.
So it would be quite feasible to intercept some of that energy as it goes back to the main distribution sub station!!  :)
Cheers Grum.
pepsimaxzu
only one thing i figured out. TK use some kind of tesla devices.100%
if someone want replicate this device and dont belive this came from tesla, then he never replicate this.
a.king21
SWER
I also made the post because I checked with a known ou contributor to Patrick Kelly's free energy pdf.
He did the experiment in New Zealand when he was working with the Adams motor.
He managed to light an incandescent quite easily.
The system of SWER is also used in remote areas of the US.
Obviously the electricity companies do not want you to know this.
It may be that some Don Smith replications are in fact SWER systems.
It is also possible that some US inventors are keeping quiet about this fact, and their devices
are not free energy devices at all.
We have to have an open mind in the free energy development field.
I am studying Tesla, Benitez and following the posts of Tito L Oracion who
I am convinced has figured it out.
I am ignoring Barbosa Leal and keeping an open mind about Figuera, which is apparently
a Lenz fooling exercise by using split cores.
Just my 2 cents.
I am replicating Tesla devices just as Don Smith did. It's the only way to learn.
(The Igniter patent  and the Ozone patent 1886 to 1888)
If you look at the Kapanadze patents- it's essentially a make-break device using coils and caps.
In other words a radiant energy device.
captainkt
@Grumage,a.king21, please post simple sketch showing what you are suggesting, as a sparks I cannot see how you can intercept either the supply or return to get any electricity out of grid. Even if you use current transformer on either wire ( in fact live, neutral, earth or earth ground) power still reads on supply meter . Unless interception is before pole transformer in which case just blatant stealing.
Keith
