0 Members and 478 Guests are viewing this topic.
romerouk
Quote from: slapper on June 11, 2010, 09:28:43 PM
So not only do we have light but heat as well.
This is good. Have you a sense as to what parameters your are looking for with this liquid?
Thank you!
nap
Using the spark gap deep in liquid shows some strange and nice effects and not overheating.Not to much to talk about it yet...
exnihiloest
Quote from: baroutologos on June 12, 2010, 02:37:37 AM
The best way is to put between mains socket and MOT a say 40 watts 12volts incadescence bulb (4 amps) or 2 x 20 watts @ 12volts.
If you know how much bright is the 40 watt bulb at 1,6 amps you will get an easy fool-proof empirical reading.
Very good idea. I'm now building a kapanadze device and I asked me how to evaluate the current. Thanks for the solution. And there is another interest, this will avoid me to put a fuse in the circuit  :)
romerouk
@callanan
I have tried connecting the two earth cables together not to the ground and rises the amperage up to 4.9 amps and the MOT starts smoking almost instantly .Bulbs are lit just a little bit.I will add more bulbs to see where is the limit where the brightness lowers.
bolt
Quote from: romerouk on June 12, 2010, 05:06:43 AM
@callanan
Yes i suspected this but its amazing you tell people TWO earths 10 m apart and they try one or both connected to same source like 2 water pipes connected to one and then wonder why they have smoking MOT or dim lights.
The device requires TWO earth points as it works using the earth as a CAPACITOR between the earth points and pulls extra electrons into the coil.
BTW this KAPAGEN device hitting the coil with a MOT is a brute force hack it is NOT a true kapanadze system.
To do this properly which is highly tuned modulator using power fets in push pull running at 5Khz which modulate a 50Khz HF carrier at 9kv. The original carefully well tuned device uses only 40 WATTS to deliver of 5KW. The spark gap is a tiny 4mm corona stream and runs cold.
baroutologos
ExO
I ask to be excused for making too much posts, but older member should remember and new ones should know that most things i post is not theory (if not said so) but I have experimented with it, really. I do so because of the excitement that we have perhaps a new technology emerging. :D
@Romerouk,
QuoteSo the ground does indeed makes a difference huh? :) Lets stick to it for a moment.
Try omitting all grounds altogether. Just the MOT and the coil setup. Can you please?
EDIT: Ok you have done it! cool. So the ground and its "capacitative ??" aspect does indeed affects the setup considerably.
Need also other to confirm that. (no offence meant of course)
Secondly,
What about the coil. Has it be that weird way? A standard coil or just inductunce with the usage of the two distant grounds what effect would have?
You see where i am getting it to. To discover what contribution each part has and to what extent.
