0 Members and 170 Guests are viewing this topic.
Zeitmaschine
Quote from: Farmhand on January 10, 2014, 09:27:43 PM
There is no "bi-filar" coil in that patent that I can see, the spark gap is connected in parallel with the Secondary S.
There is also no spark gap. F is simply a rotary switch driven by oil (in the absence of transistors or tubes).
The connection of the coil S is drawn in the same strange two-wire way like the coils in that Kapanadze patent.
Now if we wind a coil with coaxial cable then how to depict this coil graphically in a schematic? What would be the symbol for that?
If the coil S would be a coaxial cable then the inner conductor would be connected to the two capacitors (acting as an ordinary secondary coil) and the shielding would be connected to the rotary switch. Hence what could happen when that shielding is short-circuited with high frequency?
Since »G represents an electric generator, as for instance, an ordinary alternator« there would be high voltage with low frequency in the secondary coils S. The capacitors will not conduct that low frequency but only the high frequency generated by shorting the shielding-coil S.
Conclusion: Some unexpected things could happen. :)
Hint: P and S is not immersed in oil, so obviously no cooling is needed on the input side but on the output side.
penno64
Guys,
The above is simply a Fisher & Pykel washing machine motor and their hydro drive reminds me so much of the
guy that demos running a light bulb from the water pump used to turn a wheel connected to a generator. That video has been posted
several times on this forum.
I must say, there has to be something in COMPRESSING fluid !
Regards, Penno
