0 Members and 160 Guests are viewing this topic.
romerouk
Quote from: bolt on June 12, 2010, 05:29:55 AM
Yes i suspected this but its amazing you tell people TWO earths 10 m apart and they try one or both connected to same source like 2 water pipes connected to one and then wonder why they have smoking A or dim lights.
The device requires TWO earth points as it works using the earth as a CAPACITOR between the earth points and pulls extra electrons into the A.
BTW this KAPAGEN device hitting the coil with a MOT is a brute force hack it is NOT a true kapanadze system.
To do this properly which is highly tuned modulator using power fets in push pull running at 5Khz which modulate a 50Khz HF carrier at 9kv. The original carefully well tuned device uses only 40 WATTS to deliver of 5KW. The spark gap is a tiny 4mm corona stream and runs cold.
I 100% agree with you, I know this is brute force using the MOT, but it is at least a way to start towards better configuration.This is what I am trying anyway. The earth acts like a capacitor and like you are saying it pulls extra electrons into the coil.I know that for sure because I have tried using normal different values capacitors betwen the 2 grounds and I have no extra power visible to the bulbs.The coil makes a difference too, I have tried using just the long coil and it is not working properly.Other arangements in the coil might be better but I have not find a better one  yet.
bolt
Quote from: romerouk on June 12, 2010, 05:52:36 AM
romerouk i posted  several solutions to improve this kapagen to lower the current. I know you have a few MOTs and for a start adding one in series with the mains as a ballast and adding motor run caps in series and parallel and tune power factor to lowest current draw should easy half the current. Just this little mod may allow the device to run much longer possibly permanent without overheating anything.
IMO little point making accurate readings till the device is stable and cool running to eventually make a true alternative power source for practical applications. PS im also in the UK SW just FYI.
romerouk
Quote from: baroutologos on June 12, 2010, 05:30:28 AM
I ask to be excused for making too much posts, but older member should remember and new ones should know that most things i post is not theory (if not said so) but I have experimented with it, really. I do so because of the excitement that we have perhaps a new technology emerging. :D
@Romerouk,
EDIT: Ok you have done it! cool. So the ground and its "capacitative ??" aspect does indeed affects the setup considerably.
Need also other to confirm that. (no offence meant of course)
Secondly,
What about the A. Has it be that weird way? A standard coil or just inductunce with the usage of the two distant grounds what effect would have?
You see where i am getting it to. To discover what contribution each part has and to what extent.
Slowly I discover  the contribution of every part.It is so easy to do this setup but I can see that people are not really folowing my small sugestions based on the testing so far.Up to now the most important thing in the setup is not the coil, it is  the 2 earth connections and I can see that most of the replicators are ignoring it.If you don't have access to have 2 separate grounds don't even try to continue.
I need someone here to replicate it properly then the presure is not as much on me, I get lots of emails with questions...
forest
Quote from: romerouk on June 12, 2010, 06:05:01 AM
This really imply the potential difference between grounds (aka displacement current) and I recall in Kapanadze videos exactly one guy measuring voltage between water pipe and a piece of wire (not sure where it was connected though). Can you measure voltage between those grounds ?
bolt,
what is needed to eliminate one ground and just stick with water pipe as only ground ? That would be huge improvement and allow others (located in urban areas ) to follow...
romerouk
Quote from: forest on June 12, 2010, 06:17:10 AM
This really imply the potential difference between grounds (aka displacement current) and I recall in Kapanadze videos exactly one guy measuring voltage between A and a piece of wire (not sure where it was connected though). Can you measure voltage between those grounds ?
bolt,
what is needed to eliminate one ground and just stick with A as only ground ? That would be huge improvement and allow others (located in urban areas ) to follow...
I am thinking to use one ground and the other one is going to be 'connected to air' . Few years back I had some experiments where an antena and the ground produced some power, around 500mv.I will have to do that test again and see if it going to help here.
2 antenas having them at  0.5m away from ground and another one at 1m from the ground can act like a capacitor, drawing electrons.
I have measured the power betwen the ground and the  water pipe cable and I had around 20v.
If I connect the water pipe cable to one of the grounds the brightness increases.I will try with many different grounds connected togheter....
