0 Members and 537 Guests are viewing this topic.
bolt
Quote from: forest on June 12, 2010, 06:17:10 AM
This really imply the potential difference between grounds (aka displacement current) and I recall in Kapanadze videos exactly one guy measuring voltage between water pipe and a piece of wire (not sure where it was connected though). Can you measure voltage between those grounds ?
bolt,
what is needed to eliminate one ground and just stick with water pipe as only ground ? That would be huge improvement and allow others (located in urban areas ) to follow...
You can measure static voltage perhaps 1.5 volts between earth points i explained already this is "bird on the wire" you measure and can not see the huge amount of power in the earth. Only when its disturbed you change the PD  and so THEN you can see the power.
Different type of system required i already posted a while back. In essence 2 earth system is Extra Low Frequency then one earth system is Long Wave now capacitor is the earth to the sky then no earth is virtual earth aka TPU requires VHF operation and the most powerful systems are HV dielectric uses  Gigahertz operation flat AIR capacitor plates. Don Smith latest and maybe the last system uses AIR caps. The two points then exist BETWEEN the dialectic and the wavelength is millimeters!
There are no special frequencies people in vain search for magic Overunity frequencies is simply disturbing the ether at almost ANY frequency from HZ to Gigahertz. Radiant Energy = RF in zero Node where Power Factor is trashed or VSWR is fully reflected.  This is why HUNDREDS of OU examples of systems exist covering HZ to Gigs. Even DC is not really DC a battery depletes in a very long slow SINE wave.
As old radio years ago required a good earth and a long wire antenna  and this radio was so VERY close to OU power plant as MORAY system.
dole
Hi all
I have to admit that using NST and Ignition transformer 10kV (variac on input and DC to) did not work well, no OU, with caps I guess visually up to 80% efficiency, at least not with coil specified. So I think start point may be to replicate exactly, if it is possible at all.
@all
Please if there is someone tested other input sources and relation to design, it would be of interest to all. I do not have MOT jet.
@Romerouk,
Would you be so kind to verify this, did you try with some other HV transformers as input for this particular coil?
d.
romerouk
Quote from: dole on June 12, 2010, 06:40:56 AM
Hi all
I have to admit that using NST and Ignition A 10kV (variac on input and DC to) did not work well, no OU, with caps I guess visually up to 80% efficiency, at least not with coil specified. So I think start point may be to replicate exactly, if it is possible at all.
@all
@Romerouk,
d.
I tried with 2 NST 6 and 9kv without success.It might be also because these 2 NST I have are very sensitive having internal protection and turns off if the spark gap is not properly adjusted.
I had better results using an old high voltage transformer from a monitor.
Oke thanks then can we forget about the NST talk and move forward. Stick to the MOT, the more bulbs you can burn the better. There's a lot of useless text and talking in circles, we need more bulb burning talk. Consider the MOT circuit to be final and work on tweaking the coil windings for most effect.
callanan
[A author=broli link=topic=7679.msg244777#msg244777 date=1276341498]
[/quote]
Look at how many lamps JLN has increased to. I bet he has put on even more by now. He is a very smart and accomplished gentleman who wouldn't put up pictures and video representing something without a good and credible reason. I am sure he has done and tried many more variations but has simply put up what worked for him for everyone to see and replicate at their own risk without encouraging or exciting people who are less experienced to take risks with their health and safety.
