0 Members and 90 Guests are viewing this topic.
the_big_m_in_ok
Quote from: the_big_m_in_ok on January 14, 2014, 09:06:36 PM
@Acca
       On the 'Akula0083' picture, several of the coils have input or output leads that aren't otherwise going anywhere.
(Not much time on this borrowed computer---I'll probably need to reedit this post some to get it all in.)
To wit:   Posted Reply #20641, this thread page, #377
       Further...
1) The top lead of L1 as an input?
2) Both leads of L4, pointing to the right?
3) Both leads of L8 & L9, pointing down?
Where do they go; what voltage and/or current as an input or output for any and all of them?
      Oh, BTW, thanks ahead of time.   I liked the drawing so much, I copied off a color print and then enlarged it to 11 X 17 on a public library copier.
--Lee
Sorry, my typo.   The thread pg. number was actually #1377, but the reply number is correct.   Everything else remains the same on the post.
elementSix
Quote from: Acca on January 15, 2014, 07:31:43 AM
  "COAXIAL "cable is used all over the russian and polish forums, it's a critical item !!
in their Akula0083 as well as the Kpanadze builds !! and there are working builds that I know for  fact !!
links to russian and polish clips (and it just spent 5 miunutes to find them) ..
This is my buddy (Polski polak)as I am Polish and read russian also,  who also has made a "coaxial" capacitor builds!! As well a "Mnogo" many ...russians using a making power devices, here now ...
It seems like the "americans" are having a hard time cracking the "english" barrier ??
90 % of all the Kapanadze / Akula0083 are NOT in english and don't show up in english
and so it's a dis-advantage to americans..  alot of russian posts are just simple file tags that are linked to the russian forums and are not "findable" at all..
The forums are the way to search for the builds.. and there is a sh** full way tooo may  link here ...
I am trying to make my new setup with Coax cable, can you tell me if it needs to be shielded or not??  I also am wondering how to tune it and if it should be used as a bifilar configuration?  Thanks Acca ahead of time..
zcsaba77
Quote from: Acca on January 15, 2014, 06:22:26 AM
More photos...of Power coil dis - Winding !!
Hi Acca
Can You post parameter about this generator? Thanks
regards zcsaba77
Jack Noskills
If you can build, you should take a look at this.
http://www.overunity.com/14211/lenzless-resonant-transformer/new/#new
I discovered resonant magnetic flux effect. Output does not affect input. Output power depends on the Q-factor of the resonant LC-circuits. Transformer gives out more electrical energy than it requires to run. Magnetic energy is contained within the core and it is used to efficiently create electrical energy.
I did a low power version, see how much it can be scaled up. There is a pdf which exlains why it works. If you agree with my conclusions then maybe it is time to have a go at it.
captainkt
@Jack, thanks, makes a lot of sense will play this weekend.
Keith
