0 Members and 1047 Guests are viewing this topic.
dole
Thank you for your prompt reply, Good, then we probably now that we dealing with very sensitive frequency/impedance match, suppose that's way TK need freq. adjustment.
@Romerouk,
Do you have opportunity to measure Inductance and Resistance of each one coil separately and together as well as on MOT prim/sec?
And if there is some effect of grounding on non load side to be 100% insulated in ground, I mean metal dig in and connected insulated (capacity).
d.
Frederic2k1
I'm very sceptical with FE-Devices, which need a ground and are driven by the mains. I hope you are aware of the fact that in some cases you take adavantage of asymmetric earth connections on the windings of the local transformer-station in your neigbourhood. So in this case you are stealing energy from the energy-company.
sincerely
callanan
Quote from: Frederic2k1 link=topic=7679.msg244783#msg244783 A=1276344542
sincerely
It didn't take long for someone to claim such a possibility. Even before the Kapagen could be independently verified to work.  So one wonders what some sceptics and paid provocateurs will start claiming should any device that is shown to extract energy from the ground be verified and replicated...
Frederic2k1
@ callanan
Sorry, my intention is not to discourage someone, but it wouldn't be the first time on this forum that someone takes adavantage of asymmetrical earth-connections on the local transformer station.
dole
Yes, bay the way, test mentioned (80% or less) performed by Inverter and 12V input through insulation transformer to protect inverter. So it would be important to check for main to earth leakage in the neighborhood and verify system with independent energy source.
PS.
But there is some strange anomalous observed, what we could discuss later, but lat as replicate first.
@Romerouk,
I would be very pleased to info on Inductance and Resistance of each one coil separately and together as well as on MOT prim/sec
d.
