0 Members and 1584 Guests are viewing this topic.
Hoppy
Quote from: madsatbg on January 28, 2014, 05:14:50 AM
http://www.youtube.com/watch?v=SWRrEcLHZrM
p.s. we can continue to ask questions such as: why the sky is blue, why water is wet ... :-\
Yes, with a power supply connected. I rest my case.  ::)
penno64
Hi Madsatbg,
How nice to see you back.
I've been following your attempt at the eternal flashlight system.
Wishing you good luck with it.
Regards, Penno
Dave45
Quote from: verpies on January 28, 2014, 02:26:51 AM
Yes.
The disambiguation occurs when a power supply is connected to this LC circuit.  ...or a resistor (load).
No, an ideal LC circuit does not produce anything ...at most, it stores energy.
Its the bait  ;)
Dave45
Not to get off track, but just some idea's about parallel and series resonance.
I designed this back in 2012 but never tested it, another project I planned to get back to  ::)
the inner smaller cores were meant to magnetically shunt the primary and secondary's are wound on the outer cores in parallel.
I still have the model, I think I need to test it  :)
pepsimaxzu
in my opinion , we know how pump current to ground. we have to reverse this principle and current will go from ground.
by the way, i somewhere read that resonant circuit store energy and this energy is only heat, then why we dont use this for warm up water for example?
edit: now i think, may be TK just steals from AC distributors. Tesla clearly said earth acting like big rubber, and AC compannies pumping to ground energy every time. we just need coil with big selfinductance resonate at 50 hz or upper harmonic.
