0 Members and 205 Guests are viewing this topic.
penno64
leo48
From my analysis:
- The alternator so small runs too slowly to provide 3 kw
- To transmit the motion has used a spring which is too small
to transmit power even considering the low speed high torque then ....
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
zcsaba77
Quote from: penno64 on February 02, 2014, 04:48:01 PM
the two nails hammered through the timber into ????
He sucking electrons from ground (main power)!  ;D
cheappower2012
I watched the video's,the main claim is a magnetic motor,that self runs and provides
a lot of torque.The generator could have been modified to run at low speed thats not a
big factor in this case.I don't buy that the generator outputs 3kw more like 1kw at most.
More needs to be more known about the motor,and as pointed out by others the motor needs
to run by its self.
It is said that a magnetic motor is impossible,however I'm open to seeing more,before I say
its a fraud.
Its very hard even if it is real to show its real in a video,showing the motor,runs
on its own,
and can generate good torque ,goes a long way to prove that.He needs to show what happens
to the motor,
if he doesn't spin it first,does it slowly start up or doesn't at all.The skeptics will say hidden grid
wire,generator is motor,special effects wire removal,I'm not saying it might not be fake,I am not sure on this one.
I am very sure on all the Russian replication kap's as being frauds each and every one.
Zeitmaschine
Quote from: cheappower2012 on February 02, 2014, 07:29:24 PM
Why does a magnetic motor need a generator and light bulbs as proof it is working? Showing a rotating magnetic motor without fancy add-ons would be sufficient, wouldn't it?
