0 Members and 459 Guests are viewing this topic.
vrand
Quote from: dole on June 12, 2010, 06:44:17 PM
If someone still doubt and in the meantime of hard work.
http://www.youtube.com/watch?v=eqlsDJYM0hg
Apologize if many have seen this before but it helps.
d.
Alexander Chernetski died before his time, in 1992, and no one has followed through with his free energy plasma research since then.  Don Smith patented a plasma FE device but has not shown his working device it to the public.
There is something special with plasma, the forth state of matter,, in the "Free Energy" field.
Spark gaps used Kapagen and Tesla coils produce a plasma.
"Electrical discharges typically produce a plasma of ionized gas which is usually luminous."
http://www.eng.tau.ac.il/research/laboratories/edp_lab/photogal_files/photogal.htm
Here are some Free Energy devices using plasma:
http://peswiki.com/index.php/Directory:Plasma
The 1970's Papp Engine was one of the more famous usage of plasma in a car engine. There is even research continuing by the company PlasmERG:
http://plasmerg.com/
Regards, Mike
@bolt is there a reason you are not building it? You seem to giving a lot of advice without any practical example. If there's a reason perhaps someone can help.
baroutologos
Hello,
I see few cannot hold their horses and go wildy theorizing in an effort to connect every FE in a single principle. :) We do not need theories right now. We need confirmation and experimentation.
@Dole, flathunter,
In standard Tesla coil spark-discharge setups of an NST (or ignition coil) charging a cap which is discharged disruptively via a spark-gap:
* to a coil and loads (bulbs) or
* to a coil that is inductivelly coupled (with various degrees of coupling coefficient) to another coil which is connected to a load (with or without resonance between them) or
* to a Tesla coil secondary that this is again coupled inductively to another coil with loads,
in all above situations not a single time OU has been observed. Efficiency ranges form 80% 1-2 case to 50-40% third case.
What i am saying is that, for the time being stick to Naudin/ROmerouk suggestions, using this weird coil setup and TWO grounds physically seperated and spaced far apart.
@ Frederick2k1,
Sure Kapanadze generators raise few eye-brows concerning the mode of 50Hz operation regarding stealing energy. The point is how you can steal energy on those setups?
I think technically is impossible.
Not to mention the cap-discharge approach that ROmerouk is using also which frequence of cap-discharge has nothing to do with 50hz.
@ Romerouk,
so so far 16x100w light bulbs in decent brightness got? Nice news . EVen if this decent brightness is 50% wattage 800watts or even 30% wattage equal to 480 watts is still OU according to input. 1.8*240 = 432w.
By the way, i cannot stress more the urge to fool-proof measure your input. So far you are the only claiming such an extraordinary result. Ok Naudin also perhaps. (211watts, at france that would equal to 0.9amps for lughting his lamp series)
Just use the 12volt lamp method between MOT and mains.
@ All,
Those who have the setup made, should really look for good grounds physically spaced apart. Not a pipe connected here (ground 1) and same pipe connected 10m further!
According Romerouk testimony, the ground is making a huge contribution.
We should strive to replicate Romerouk/ Naudin setup and let NST, ignition coils etc at bay at the moment.
Most homes have a real ground connections which is a long metal rod stuck in the ground for protection. I know I have one in the yard.
vrand
Quote from: baroutologos on June 13, 2010, 02:43:43 AM
@ Romerouk,
How about powering an electric heater?
Heating is after lighting, one of the most energy we use in our homes.  If this device can be used to heat our rooms for less energy that would be a breakthrough.
Regards, Mike
