0 Members and 45 Guests are viewing this topic.
verpies
Quote from: d3x0r on February 06, 2014, 10:04:13 AM
What really gets me, is I was the one to told to 'stop spouting nonsense' when I first attempted to correct this..
If you keep insisting on the current reversing on a coil, I don't know how you can make any forward progress, since real observations will never align with your imagined framework
"stop spewing nonsense" is not a valid form of scientific argumentation.  It is an Ad Hominem remark that's a typical characteristic of rude and ignorant people.
The "back EMF" or "inductive kickback" does not cause the reversal of the current flowing in the inductor before an attempt to interrupt this current.
It is a common misconception reinforced by the word "back" and the lack of realization, that the "inductive kick catch diode" is connected in parallel with the inductor - not in series, relative to the power supply.
Grumage
Dear All.
I have just tried to log in at Energetic Forum and have been met with Go Daddy !!
Is anyone else having the same problem ??
Cheers Grum.
ALVARO_CS
yes, me too
other people from other countries report the same all around
dllabarre
Quote from: Grumage on February 06, 2014, 12:24:01 PM
Dear All.
Cheers Grum.
EnergeticForum.com - probably just an oversight of the owner.  :P
"NOTICE: This domain name expired on 2/5/2014 and is pending renewal or deletion"
Zeitmaschine
Quote from: verpies on February 06, 2014, 10:43:18 AM
If the voltage developed across this coil is offered a conductive path and allowed to cause current flow, then the magnet will be braked :(
What exactly is a conductive path? If we capture the electrons from ground, then route them through a load and then give them back to ground, is this considered as a conductive path?
Quote from: Dave45 on February 06, 2014, 06:20:30 AM
When we pulse a coil in just and ordinary transformer we'r hitting the coil 180 degree's out of phase(each side of the coil winding) with 120 cycles but the voltage on the scope shows 60 cycles with a 90 degree phase shift and the current also has a 90 degree phase shift at 60 cycles, a coil separates voltage and amperage or pos and neg however you want to look at it.
My today's theory goes as follows: When a coil is shorted the magnetic field in the core collapses very fast (when disconnected from source) therefore the coil (or a second coil on the same core) attracts additional electrons from ground (or a metallic object), then these electrons are able to boost the current in the load circuit. That theory sounds rather simple, so what's still the problem?
Actually the SR193 wiring does not make any sense (yet). What are we missing here? The two thyristors or transistors or triacs (?!) are connected with only two thick white wires (anodes or A2 to transformer?). All other wires are thin. Assumed that these are triacs then the question is, are all TO220 triac pin-outs in the A1 A2 G order or are there also triac pin-outs in G A2 A1 order?
Interesting coincidence by the way: The connection theory of my basic transformer circuit looks like the transformer of the 00135 device which looks like a line filter coil which looks like the two filter coils of the Steven Mark TPU. Hmm ...
Are we perhaps close to the solution or rather close to the madhouse? ::) ???
