0 Members and 1912 Guests are viewing this topic.
bolt
Quote from: aether22 on June 13, 2010, 01:16:09 AM
What kind of farad value caps would you expect for input PF correction?  Or how would you find out?
I can't find a MOT, guess I killed them all on replicating Thanes mot/gen, guess I'm looking for a junker μwave...
You make a Binary Cap box!
Sooner or later you WILL need one to tune these systems properly. Right now no one has tuned the tanks or coils anywhere near peak performance. No one yet i seen used another MOT as mains inductor to HALF i/p current. etc etc
You use  motor run caps and put them in a box with house consumer fuse style switches like 20 amp current trips.
Then you wire close to binary values like  a 1uf 2uf 4uf 8uf 16uf 32uf 64uf 100uf 200uf run caps into a box where you can switch in and out of circuit the required capacitors.
Example if i needed 51 uf i switch in 32+16+2+1 =51uf
while observing carefully the volts and current OR use mains power consumption meter many will show WATT AMPS VOLTS and POWER FACTOR.
Use the binary box to get lowest power consumption then once you found best value you substitute for permanent cap size and move onto tune another part of the system like L1 and L2 matching.
Also a series RUN cap with the mains i/p acts as a current limiter. Just this ONE simple mod can control the current on the system like 16uf cap in series with live mains will limit the current to entire system keeping things cool.
ramset
bolt
Thanks a million for your contributions here!!
your confidence and directions are priceless!
Chet
Thanks Grandma
forest
I don't get it. Wouldn't be better to just use spare parts : coil and cap and compute resonant frequency ? It is far easier to adjust frequency then inductance or capacitance.
Quote from: Chef on June 13, 2010, 10:30:51 AM
I have done that. In any way I limit the current at the primary, the output will decrease. I tried different transformers, inverters,recently I made a vibrator power supply, to use as an inverter, everything work fine, but no OU anywhere.Why I can't light up for example let's say 6 bulb, when I pump around only 130 watt to the primary side?? The whole key for that action what we see here, is the MOT which connected to the line, and could pump nearly 2000watt to the secondary side at any time.
So it can fool a watt meter and the meter of the power utility but not you? You can convince me if you have used a current probe hooked to an oscilloscope and share the scope trace. Anything else is wild speculation.
