0 Members and 200 Guests are viewing this topic.
Farmhand
Quote from: energia9 on February 16, 2014, 12:05:27 PM
all LRC circuits are below 100% efficient ,  the creation of high voltage has too much losses.  with ringing down circulation you wont get anything out for free.   if you separate charges then whats going to happen?
your circuits wire resistance, your transistors, your resistors, your capacitors, your high voltage transformer(s) and lastly the separation of charges.    very inefficient process..
and this applies to any replicator on planet earth.
If you separate enough charges quick enough something might go "BANG" hehehe.
This is what I don't get,
1) No one has shown shorting coils gets back more energy than was expended to do it, only that they can at times get back more energy that way than the other way by just using the generator coil as normal (without causing spikes to get higher voltages).
2) Why are so many people "faking" these setups with hidden wires and so forth and claiming replications ?
It is an odd phenomenon. I mean to say what is stopping the Barbosa and Leal guys from continuing on like Tariel has, and go into some other line of getting "investments" even while claiming suppression ?
Cheers
energia9
people are faking devices because they want to get attention.  they get a ton of views and praisals, but nothing gets back to people in return. only useless pointings to the dark in reality.
very.... repeated behaviour you can see all the time.
then people suffer from these fakers because they spend time energy and money on a thing that does not work and will never work.
Grumage
Dear All.
I fairly often wonder why some folk are members of this Forum !!
Overunity.Com.  Title. "Free Energy | searching for free energy and discussing free energy"
And yet we get folks that act like "The village Bobby"  "Bobby", British slang for Policeman. Whilst there is still a vestige of freedom I personally feel that I am going to play around in my spare time doing as many "Hair brained" experiments as I choose !! Please stop the negativity!! I for one could not care less what you think or say!! Just let those of us that wish to spend our time messing ,get on with it !!
Ok minor rant over !!
Cheers Grum.
Grumage
Quote from: Dave45 on February 16, 2014, 07:38:30 AM
We already know it just have to put it together.
Ionization is the key, separate the charges then collect.
There are two charges pos and neg combined neutral separated energetic,
High voltage ionization separates, separate circuit to collect what has been separated.
Separate - Collect
Dear Dave45.
I have been pondering upon your recent posts and yes I do think you have something.
Looking back to my Akula0083 replication (I call it his Mk 2 version) What have we got?? Internal Tesla primary. Driven from the middle creating separate end charges. This coil overwrapped by a larger paired bifilar coil (Collector) also driven by the same oscillator. A final single layer output coil to load.
I have seen a number of videos (some private) where they are combining electrostatic with low current to create an overall net gain in output. I am not suggesting OU but the principle is most definitely there !!
PM me if you wish so we can discuss further.
Cheers Grum.
jbignes5
Quote from: forest on February 16, 2014, 12:28:31 PM
really ? Tesla compared capacitor to explosive except there is no limit for him for getting out power from capacitor. Because capacitor work with inductance and if you follow Tesla patent chronology he first patented method of conversion by capacitor discharge then go further and ended with many patents of circuit make&break controller I strongly advice : try to not underestimate LCR circuit .... or Tesla spent a lot of money for nothing ??? ???  try to avoid R
The biggest problem is that most Educated people think in a very small box. They can not break out of that box because of LAWS they have created to keep them in that box.
Tesla knew one thing. Capacitors are the way to free energy. Why is that? Does a real current flow in a capacitor? Absolutely not. It is by induction that a real capacitor works without physical motion. The only motion that is utilized in a capacitor is the virtual voltage potential. When that varies you get output.
Yes you need to reduce the real resistance and the other resistance like effects to get real energy out. The bifilar coil reduces self induction<-Resistance of flow or current while still maintaining a raising of the voltage potential.
Lets look at why this happens. The raising of the potential is not from self induction. Well what could raise the potential then in a coil if self induction is canceled out? The speed at which the charges flow through the coil! The higher the speed gain the higher the potential of that charge moving through the coil. This is commonly accepted in particle accelerators. Why is it not accepted here? In fact the bifilar coil adds speed to the charges by using opposite entry points for the - and +. This accelerates the charges and increases the voltage potential of both charges.
In looking at the designs of Tesla and his motors/generators I think I have found out why he was getting great results. The torroid generator ring could if looked at properly provide a balanced pull from both directions if you use a pair of magnets in the center. With wire wrapped around the torroid coil in 2 or 4 single coils one could generate without massive resistance. Using the bifilar winding method in split phasing is another crucial method. Yes you will get some resistance to turning but not as much as if you used poles. Tesla described the torroid as a perfect way to get rid of load based resistance due to the things I mentioned above.
If we look back at the workshop demonstration TK did with the plated motor you see the torroid around a shaft. Did the shaft have magnets in it? I think so.... So the motor itself was a form of Tesla's steady state motor/generator. TK prolly incorporated Tesla's one terminal motor design as well into the design to further it's ability to furnish energy.
Do me a favor and go back to TK's videos and rewatch them again. Then goto www.TeslaUniverse.com and read the patents and put them together like I have. Read the speeches That Tesla did and you will finally understand what Tesla and TK were doing.
Listening to most of these guys here for the most part is not going to give you any little bit of understanding. Like I have said before most of These guys are only here to discourage you and others from realizing that it can be done. If we change our approach and understand what induction is and how it really works then we will have free energy for all.
Here is a person doing just that :  http://www.youtube.com/watch?v=8Gl45Ulf7Us&list=PLO6FJVqlxatdprKQA1BhrJCML2tbomVJ2
Good place to read about the speeches and writing of Tesla:  http://www.tfcbooks.com/default.htm
Induction is the only way to not destroy the dipole if it is done in the proper method.
