0 Members and 622 Guests are viewing this topic.
xenomorphlabs
Quote from: Chef on June 13, 2010, 10:30:51 AM
I have done that. In any way I limit the current at the primary, the output will decrease. I tried different transformers, inverters,recently I made a vibrator power supply, to use as an inverter, everything work fine, but no OU anywhere.Why I can't light up for example let's say 6 bulb, when I pump around only 130 watt to the primary side?? The whole key for that action what we see here, is the MOT which connected to the line, and could pump nearly 2000watt to the secondary side at any time.
In Kapanadze´s green box video, the current measured with the clampmeter between inverter and green box is fluctuating between 0.2 and 0.5 amps.
That would be only around 100 Watts input power.
If there would be a MOT in the green box, then the signal from the inverter would be enough to feed it. What are the 2 transistors on the green box then for?
It seems almost certain that Kapanadze is using two different types of signals that he feeds somehow to the coil (Like SR has been basically saying) .
The coil exhibits also not only one "input".
The high voltage part looks like only being in the few milliamps range of current judging from the spark gap.
So it remains to be found out how to get the same effect while reducing the input current.
grizli
Quote from: romerouk on June 12, 2010, 05:06:43 AM
@callanan
I have tried connecting the two earth cables together not to the ground and rises the amperage up to 4.9 amps and the MOT starts smoking almost instantly .Bulbs are lit just a little bit.I will add more bulbs to see where is the limit where the brightness lowers.
THAT could BE kind of prove of OU, dont you thinl ?
grizli
Quote from: bolt on June 12, 2010, 05:29:55 AM
Yes i suspected this but its amazing you tell people TWO earths 10 m apart and they try one or both connected to same source like 2 water pipes connected to one and then wonder why they have smoking MOT or dim lights.
The device requires TWO earth points as it works using the earth as a CAPACITOR between the earth points and pulls extra electrons into the coil.
BTW this KAPAGEN device hitting the coil with a MOT is a brute force hack it is NOT a true kapanadze system.
To do this properly which is highly tuned modulator using power fets in push pull running at 5Khz which modulate a 50Khz HF carrier at 9kv. The original carefully well tuned device uses only 40 WATTS to deliver of 5KW. The spark gap is a tiny 4mm corona stream and runs cold.
how can so small coil resonate at so low freq ? only 50khz ? where is the "big" secondary capaitor here ? earth ? hmm
I would say that mosfet circuit would require at least 500khz or more ?
if kapagen coil and earth can maybe itself make paralel LC resonance than maybe no actuall power l is needed hmm (theoreticly),
In Romerouk experiment is not 0,1uF capacitor  part of LC resonance of primary(tiny wire coil) across the spark gap ? maybe varioation of this capacitor will determinate proper frequency for less power used
grizli
Quote from: baroutologos on June 12, 2010, 05:30:28 AM
What about the coil. Has it be that weird way? A standard coil or just inductunce with the usage of the two distant grounds what effect would have?
You see where i am getting it to. To discover what contribution each part has and to what extent.
I would say that LH and RH direction coil is the key here.... I would say that without that this circuit will behave much worse
That should be tested also
xenomorphlabs
Picking up on that statement:
QuoteTo do this properly which is highly tuned modulator using power fets in push pull running at 5Khz which modulate a 50Khz HF carrier at 9kv. The original carefully well tuned device uses only 40 WATTS to deliver of 5KW. The spark gap is a tiny 4mm corona  stream and runs cold.
What is the benefit of this modulated signal compared with the unmodulated signal?
How is that signal then stepped up to 9kV. Flyback transformer?
