0 Members and 120 Guests are viewing this topic.
grizli
Quote from: Frederic2k1 on June 12, 2010, 08:35:27 AM
@ callanan
Sorry, my intention is not to discourage someone, but it wouldn't be the first time on this forum that someone takes adavantage of asymmetrical earth-connections on the local transformer station.
LOL
Imput is MOT which has galvanic separation of primary to secondary ... the same effect should be done using generator or battery and inverter
e2matrix
Quote from: baroutologos on June 13, 2010, 02:43:43 AM
Hello,
I see few cannot hold their horses and go wildy theorizing in an effort to connect every FE in a single principle. :) We do not need theories right now. We need confirmation and experimentation.
@Dole, flathunter,
In standard Tesla coil spark-discharge setups of an NST (or ignition coil) charging a cap which is discharged disruptively via a spark-gap:
* to a coil and loads (bulbs) or
* to a coil that is inductivelly coupled (with various degrees of coupling coefficient) to another coil which is connected to a load (with or without resonance between them) or
* to a Tesla coil secondary that this is again coupled inductively to another coil with loads,
in all above situations not a single time OU has been observed. Efficiency ranges form 80% 1-2 case to 50-40% third case.
What i am saying is that, for the time being stick to Naudin/ROmerouk suggestions, using this weird coil setup and TWO grounds physically seperated and spaced far apart.
@ Frederick2k1,
Sure Kapanadze generators raise few eye-brows concerning the mode of 50Hz operation regarding stealing energy. The point is how you can steal energy on those setups?
I think technically is impossible.
Not to mention the cap-discharge approach that ROmerouk is using also which frequence of cap-discharge has nothing to do with 50hz.
@ Romerouk,
so so far 16x100w light bulbs in decent brightness got? Nice news . EVen if this decent brightness is 50% wattage 800watts or even 30% wattage equal to 480 watts is still OU according to input. 1.8*240 = 432w.
By the way, i cannot stress more the urge to fool-proof measure your input. So far you are the only claiming such an extraordinary result. Ok Naudin also perhaps. (211watts, at france that would equal to 0.9amps for lughting his lamp series)
Just use the 12volt lamp method between MOT and mains.
@ All,
Those who have the setup made, should really look for good grounds physically spaced apart. Not a pipe connected here (ground 1) and same pipe connected 10m further!
According Romerouk testimony, the ground is making a huge contribution.
We should strive to replicate Romerouk/ Naudin setup and let NST, ignition coils etc at bay at the moment.
I don't think anyone needs to limit how things are going in this message thread.  I appreciate hearing theory as well as actual experiments.  I think they both have value and I consider bolt's info quite valuable.  Do we really want to limit getting a tidbit from someone that might be a very important point in getting this to work best?
vrand
Quote from: Chef on June 13, 2010, 12:03:17 PM
I'm not speculating, I tried it. I don't want convince anybody, I just say, don't get excited until you find out what's really happening here.
With MOT, without current limit it could light more than 1kw.
With MOT, current limited inverter (max 130Watt at 220Volt, 50hz), it couldn't light 2 bulb at full brightness.
These are my tests, I could be wrong.
What type of ground connections are you using?  Distance?  Moist or dry grounds?
Thanks, Mike
xenomorphlabs
The problem with all these Kapanadze set-ups is that it is not so obvious to which frequency to tune a frequency driving circuit, if you follow the road of wanting to feed the coil with it´s resonant frequency.
If the earth is considered a cap then we are not only looking at the coil´s self resonant frequency, but a complex LC arrangement where you would have to determine what that arrangement´s resonance frequency is.
Maybe a good idea would be to "sweep" the driver through all frequencies and oberserve for output changes?
grizli
Quote from: xenomorphlabs on June 13, 2010, 12:58:33 PM
Planet earth has capacity of about 709uF
100 turn coil similar to kapagen could have 50 uH which kind of gives resonance of 26khz hmmm not too BIG frequency after all !!!
But in kapagen circuit we dont have primary and secondary
we practicly have primary in SERIS to secondary and primary capacitor is part of the resonance etc etc ...
WHY having primary and secondary in series... why not just having secondary thick wire in series with bulbs and two earth grounds...
WHY WE need primary current and MOT current to be part of the circuit ?
without diode there mot secondary 2kV can easily light up 10 220v bulbs in series hmm
