0 Members and 118 Guests are viewing this topic.
cheappower2012
Hoppy
          The green box has enough area to hold batteries
from a skeptical view point.Under know things ,given,220 vac,50hz/60hz
a high ground current is not possible,so there are only two possibilities
one there really is a ground current in which case its a fake,a  hidden grid wire or second possibly
there is a phantom current reading,in other words pulses from the large coil are mixed with 220 vac to
produce a condition where the cheap clamp-meter shows a fake high current.The purpose is to create the illusion its a Tesla
invention,by showing a ground current,the size of the ground wire simply adds to the illusion.Sometime in the near future I will make an extensive video on  this effect.
In ether case it can be thought as a black box,x input,y output
it yields no clues on operation,its a dead end.Your too skeptical you would conclude its batteries hidden,if not hidden grid wires
and given the size of the green box its a possibility.I plan on making some videos showing new information on how SM faked a few illusions on hes presentations
and present a case where it could be real.
Hoppy
Quote from: cheappower2012 on February 24, 2014, 05:16:40 AM
Hoppy
Thanks for your thoughts. I doubt its batteries. However, as you have the same clamp meter used in the video, your attempt to replicate the earth wire current reading effect could give a very useful clue as to how Kapanadze faked self-running. I will be especially interested to see your presentation on how it could be real.
Zeitmaschine
Quote from: cheappower2012 on February 23, 2014, 08:12:32 PM
You didn't answer my question do you have conmen in your country.
I can't see the relevance of that question.
You can not have one wire current of high current,given 220 vac and,50hz/60hz
But Stepanov has it also. Why should inventors keep faking things which obviously cannot be? The idea of stealing hundreds of KW from grid with a ground wire is also ridiculous. If there is only single wire earth return then anyway the grid supply should not be very effective and powerful in order to branch away that amount of energy under the radar.
Hence my today's theory: What could happen when an electromagnetic field is mixed with an electrostatic field? The precise method does not matter. Maybe with transistors or thyristors, maybe without. Maybe with a flyback for HV generation, maybe with some other means to get a static (high) voltage field.
energia9
do i remember correctly that kapanadze said or at least has been mentioned saying "its so simple you would laugh"  ?
may be its so simple its a fake? or its so ridiculously simple that we just want to complicate everything
Hoppy
Quote from: Zeitmaschine on February 24, 2014, 06:30:39 AM
Exactly! That's why the so called ground wire on the 'green box' device is more than likely eye candy, like the spark gap. Its so simple...............The bearded guy holds the secret.  ;D
