0 Members and 210 Guests are viewing this topic.
vrand
Quote from: Chef on June 13, 2010, 01:10:09 PM
Copper pipe, but tried with iron pipe too. First 10m, but it made no difference, if i used only 5 m. Dry ground.
Maybe try adding soaking water around the ground connections. That is what Kapanadze does with his dry ground connections.
grizli
At least 3 people here except romerauk tried to replicate , why Rome made so BETTER results hmm?
why we theorize about complex waveforms ? Complex waveforms are NOT source of OU...
Does not TC reciever and transmitter together make TWO grounds... BUT one wire is air other wire is earth... one ground is reciever other is transmitter..
why not using secondary with series to load and two grounds SEPARATE from primary circuit ? why is primary currend in series with secondary low turn coil
bolt
For ease of use KAPAGEN is rough brute force hack of Kapanadze system. They look similar but thats all they operate quite differently.
Nothing wrong with KAPAGEN it gets ones foot in the door but biggest problem is too much power causing overheating of MOT and spark gap. There is MUCH room for improvement as i posted many times now. That said Kapanadze system is FAR more complex requiring at least 20 components which puts it towards only one or two really dedicated builders. 99% wont do more then a 5 parts hookup like KAPAGEN and STILL make compromise on earth even size of the wire now you would think everyone would have some wire something close to correct size?? apparently not:)
Kapanadze is a very well tuned system where every coil turn and cap has been carefully selected. It runs on HT somewhere 5kv to 20kv and perhaps 15Khz low current the FET driver stage is 40 watts. It MODULATES the HT supply using the FET amplifier. Very little current passes the spark gap.
This is NOT just my opinion its also that of about 10k forum members over on the Russian Kapanadze websites.
It HAS been replicated small scale as Russian YT video 100 watt bulb 100% looped system no batteries or mains.
All the looped systems i know use ferrite cores NOT iron made of least 5 toroidal cores from TV or SMPSU's.
Now KAPAGEN it can be vastly improved but never become a Kapanadze device not until modulation is perfected using FET driver and trash the MOT's.  Despite this builders have a lot of things to try and reason for power linked LINEAR to i/p drive is the KAPAGEN is untuned RF hash box of crud and its just luck that some of the RF spills over enough to shake the ground electrons. However because its untuned as soon as you reduce i/p power the o/p drops accordingly.  Tuning does NOT mean reduce mains i/p voltage or using variac or light dimmer circuit to drop the volts. Tuning means power factor correction on i/p and o/p plus chokes, HV diodes to DC, correct size for spark gap cap plus ballast and tuning L1 very carefully to L2 using Binary Cap box and adding the right value caps in all the right places till its peaked into a given load.
So there you have it that is where we are now. The good news is so far ONE person i seen now using NST and getting bulbs to light this means Don Smith approach is very real. So the "hundreds" of other that tried an NST and cant light a bulb clearly didn't do it correctly.
BTW a COP of 8-10 is not actually required. A COP of 3 is a potentially loop-able system so long as it runs cold/warm 24/7.  A stable system of just 500 watts running 24/7 that creates minimal EMI is infinitely  better then a 2kw system that melts after 10 mins use. And if you need more power you make 2 or 3!!
grizli
Quote from: bolt on June 13, 2010, 02:33:14 PM
But tuned LC circuit is NOT source of OU ? Question is what has to be tuned to WHAT.. it is NOT problem to tune problems is what to what ? whats going on here with two grounds ?
Again I ask why low turn secondary is in series with primary ? why secondary is not free from primary ?
vrand
Thats about right, 1 in 10,000 got replication.   ;D
But even that one guy that did it does not show how he did it, so that others could replicate!?!
- Bolt, have you seen that Russian's circuit and parts list to light up that 100 watt bulb?  URL?
Any invention replication attempts with over 5 parts is EXTREMELY difficult to replicate without Exact parts specifications and diagrams.  Even then it will most likely fail, as the transistors parts mfg are different in quality and the need to be tested to see if the parts are to specs.
