0 Members and 65 Guests are viewing this topic.
elementSix
Quote from: jbignes5 on February 27, 2014, 11:37:50 PM
The effect you are seeing is what we call the Captret.
Warning: Utilizing the can on Capacitors as a separate plate causes the inside to cone and push the cap apart, Unless it is designed rigidly it will destroy the cap eventually. Solidly built cap will last much longer. This usually means the bigger the better. They actually make very heavy caps with a threaded bolt on the end cap. These type of caps can handle huge stresses and will fair better then rubber plug caps.
The one pin goes to the can and is supposed to be used for extra support for the cap. Most caps like this do not connect the extra lead to the can but it looks like you have one that does. Do a search for the word Captret and you will find IBpointless2 and my work on them.
Its good that DilJalaay asked that question and you Jbig..  said that about the Electret.  I was having problems with my new build of the conversion device I  made.  I always thought that the TPU and TK's device worked on EFNMR (Earth Filed Nuclear Magnetic Resonance).  Which works the same basic way.  Just in a different way.  I read this website on the secret to free energy and it talks about Ridged Capacitors are needed for the capture of Ambient Energy.  I made my own capacitor for my TK working setup.  Low ESR capacitors are the best to use.  But I found that if current flows in the discharge circuit and primary it will destroy any chance of tapping the ambient energy field.  This page talks all about it, but it also talks about the T1 relaxation period for the collector circuit wire.  Different wire has different Relaxation periods.  So timing of the impulse is very much apart of the setup.  Thats why when some one has a real working replication that they made using old wire and someone uses new copper wire to replicate with.  It won't work the same because the old copper wire has a different T1 relaxation time than newer copper.  I think thats why some use steal wire, like Steve mark did in one of his TPU's.  The voltage is the power producer in a FE device.
So if what DilJalaay said is correct with that third pole on those caps, then they would be the best use for tapping the ambient field.  I am going to use the ones I have, but have to change the wire lengths and some other shit because they are large caps.
Heres a link to the pages with beardens and others writings.  Also The caps I found had a charge after siting around for 3 months.  I discharged them and today they had a large enough charge to spark when I shorted them.
http://www.docstoc.com/docs/document-preview.aspx?doc_id=9641970
http://www.cheniere.org/techpapers/Final%20Secret%2013%20May%201994/
An Ideal Capacitor Is an Electron Current Blocker
We point out that, if the capacitor's components are ideal,  completely rigid, and do not physically move, then the capacitor is a "dm/dt blocker." If the charges really were frozen in place, then the potential would flow across the plates at the speed of light, via the flow of excess massless displacement current dØ/dt. In that case, an ammeter would not show the classical "exponential fall-off" of the current with time; the electron current dq/dt would occur as a single-point Dirac delta function at t=0, and would be zero thereafter. And no electrons would be able to move in zero time. The voltage would show an instantaneous adjustment to the charged value with a single step-function, and the capacitor would charge up fully, instantly, with no work (energy loss) whatsoever being done. And this charge-up of the capacitor would not dissipate in the slightest the source furnishing the voltage; there would be no electron current dq/dt through the back EMF of the source, hence no work inside it to deplete its separation of charges.
Problems With Ordinary Capacitors
However, most ordinary capacitors are much more than just an ideal capacitor. The plates move, the dielectric moves, etc. due to the forces created upon them by the E-fields created upon the trapped charges in them. The spatial translation of the resulting force moving the plates constitutes work; i.e., it dissipates some of the flowing dØ/dt energy. Each movement of the plates and/or dielectric carries with it all its internally trapped charges. The movement of those charges constitutes a substantial longitudinal electron current dq/dt,  when compared to the longitudinal "drift" electron current in normal circuits. [Electrons spend most of their time moving radially in a wire, not down it.] This "moving plate and its transported charges" make an electron current, which pumps the inert electrons in the ground return line back through the back EMF of the source, depleting the source. Consequently, the ordinary capacitor will simply release as much energy as work (to move the plates and dielectric) as it stored. Hence, it will also produce dissipation of the source via the amount of energy stored in the capacitor. You still get "free energy" stored in the capacitor, but also dissipate the source by an equal amount.
Rigidized Capacitors Must Be Used
Only rigidized capacitive collectors are useful in free energy devices. Such capacitors are in fact actually available, e.g., as calibration standards, but they are extremely expensive ($400 to $2,000 or so each, for a capacitance reaching about 1 uf).
So, capacitive type collectors must be rigidized, if used in overunity circuitry. Even so, in a single integrated circuit, although one collects free energy, one will use half of what was collected to dissipate the source. Not all the remaining half will be discharged through the load; some will be discharged in other circuit and component losses. Hence, there will always be less work done in the load than is done in the source to kill it, by a conventional two wire single closed circuit. In my second referenced paper (Feb.94), I included precise proof that this is true. One must use energy collection and shuttling between two isolated circuits, and the load discharge current must not pass back through the primary source of potential.
We have previously provided precisely how to utilize capacitive collectors in our two referenced papers. We point out here that the capacitors must be calibration standard capacitors, or specially made rigidized capacitors.
elementSix
That 30 Watt Akula circuit must work, cause there are 4 versions of it out there.  I wonder which one is the one he made.  Everyone has to fuck with things and put what they think it should look like.  Then you have the disinformation process, which is to modify the circuit just a tiny bit.  So its not really noticed an then the whole device is ruined and won't work.
totoalas
forest
Quote from: totoalas on March 01, 2014, 10:20:56 AM
Circuit simulation from tech gurus   anybody  8)
can't work in simulation, simulation need always established science..but some part can be modeled I think . working on it
