0 Members and 1047 Guests are viewing this topic.
xenomorphlabs
I think Bolt referred to SR´s replication and there is no parts list for that 150 watt bulb experiment. He refused to share it.
The parts are pretty much all visible in the video.
He does not say how he wound the coil and what the signal looks like (frequency) that he feeds to it.
Some russian forum members  seem to have identified in that video a small CFL HV circuit board, that he might use for the HV generation. That would indicate that at least for the HV part he is not after a custom frequency, but merely needs any kind of HV signal to "support the process" as he described.
grizli
I dont know have you noticed before or not but this is different than Romerauks replication
http://jnaudin.free.fr/kapagen/kapagen1200Wa.jpg
Follow the wire
Naudin blue coil wire goes to the end of tube and changes direction when is attached to Yellow wire : magnet field of blue wire is in OPPOSITE direction than magnet field in yellow wire
Romerauk magnet field of blue wire is in the SAME direction of the magn field yellow wire
Naudin :
WE actually have PRIMARY in series to secondary but current induced in SECONDARY is in opposite direction to primary current
In rome's replication all three coil follow the SAME magnet field orientation
xenomorphlabs
Quote from: grizli on June 13, 2010, 03:19:37 PM
Follow the wire
Naudin :
You have obviously missed  segments of this thread.
Your observation is wrong. Romerouk has confirmed to having used variant B of this diagram http://www.overunity.com/index.php?topic=7679.msg244409#msg244409
He goes from CW to CCW.
vrand
Quote from: xenomorphlabs on June 13, 2010, 03:14:29 PM
Bingo, that is the EXACT reason why the FE field never got off the ground.  The original inventor never tells exactly how its done. Then if somehow someone else does manage to figure it out, they do not share the info on how they did it!  Crazy!
At least Jean Louis showed a video of the inner workings, (Thank Jean Louis  ;D) so that Romerouk and others here could then reproduce it and then share their results (Thanks Romerouk and all ;D)
This whole FE field is littered with 10's of thousands of failed reproduction attempts and 10's of millions of dollars spent over decades, all for lack of detailed information from the original inventor.
With Romerouks sharing of his experiment results info we now have at least some key elements to making it work  ;D
bolt
Quote from: grizli on June 13, 2010, 02:47:17 PM
But tuned LC circuit is NOT source of OU ? Question is what has to be tuned to WHAT.. it is NOT problem to tune problems is what to what ? whats going on here with two grounds ?
Again I ask why low turn secondary is in series with primary ? why secondary is not free from primary ?
Without resonance you cant tap the OU which exists in earth current as sample is current NODE.  Where RE = RF in standing node applications ALL systems of OU are the same where any type of coil cap circuit. For Kapagen OU tap is earth current which flow through the earth in abundance and 10 m tap is wavelength sample. You are only selecting like a 0.00001% sample of the wavelength but its enough to pull KW's.
A resonant hi Q circuit tends to have a fixed decay rule of thumb .372 or 37.2% per full wave oscillation. A spiral is manifested as logarithmic gain at a rate of 1.618 within sine wave gain curve within a virtual oscillatory wall = stochastic resonance. I only to provide for the entropy loss and convert loss to gain to maintain 100% oscillation. As RE enters coil at NODE 0 magnetic      amplification makes up for the entropy loss.
Radiant Energy only flows into a circuit of resonance  at zero current node so RLC = RE.
Tuning requires L1 driver is true magnetic coupling to L2 where L1 = 1/4 wave driver and L2 is resonance amplifier. L3 is current collector of magnetic field of amplified energy about coil L2. This is WHY L3 6 turns is positioned RIGHT hand side of L2 where current is to the right volts to left and equal split is center collector. The wires maybe connected to your eyes in series but magnetically at low frequency operation are seen as separate coils.
At resonance R becomes L and L becomes C and C becomes R.
So you asked what to tune? do you think a random wrap of wire around a plastic pipe will be properly tuned? I doubt it so there is your starting point. Read Don Smith pdf he will give you a good head up on these systems. Voltage is everything its potential joules. Current is a POST operative effective of volts being depleted through a load creating work. BUT if i keep the volts alive without depletion they are aways there for future work.
