0 Members and 142 Guests are viewing this topic.
cheappower2012
magpwr
Tariels device is real,only very well hidden,he hid the device because
its real in my opinion.
Aukula is fake so you have hints,but if none of hes devices really
work,self running ,then your wasting your time.I'm  not trying to say overunity is not possible,
however only an energy converter is allowed under conservation of energy and matter,
the energy source would have to be an unknown energy source.It is very easy
to make a video where you show inputs and outputs and show that there are no hidden wires,
and a small space to rule out batteries and run it long enough to be convincing its real or maybe real.
Akula's use of high frequencies is another indicator its fake,I have seen at least a 100
devices using high frequencies in ever case, none were overunity.I don't want to discourage
you from experimenting just be aware there are a lot of people that get joy from faking people out.
I also experiment constantly,this picture is a modified 750 watt inverter,its been modified as a stand alone
160dc to 110vac inverter,it is an equivalent in operation to the trip-light inverter used in the old tpu video's.
The inverter is being fed dc,lighting a 100 watt bulb,all input current and voltage is monitored.
It will power tools if you supply enough current,it will be used in up coming videos I plan to
build a case for the tpu and Tariels device as being real world device's
elementSix
Hey Grum,  Heres a video I am sure you saw, its on the homepage and its just a cool looking engine.  The point is that when he adjust the voltage to a resonant point, the output goes way up.  It's just an example of one of the laws you need to abide by when tuning your generator.  Below is just a link to the video.  He shows the resonant point around 17 min..
http://www.youtube.com/watch?v=8Gl45Ulf7Us&list=PLO6FJVqlxatdprKQA1BhrJCML2tbomVJ2#t=1071
Akula in my opinion is a genuine article.  From Wesleys translated videos on how his device works.  He talks about most of the points that I laid out when I posted all the info on that energy conversion device.  I am not a professional at making circuits like Akula is,  or making circuits period, thats why I could only make a mechanical switching device.  But from what he says it seems very apparent that he knows what hes talking about.  Plus the fact that everyone is calling him a fraud, even thoe they haven't even tried to replicate his small and simple devices.  Like the little 5 watts or so flashlight(torch), which is his version of the eternal flashlight from last year that came out.  The Non-Linear Induction Generator.  I posted this circuit that has very good potential.  I wouldn't say its perfect, but its a good starting point.  I would change a few things like running the transistor with a square wave generator like Akula uses and maybe try the CW and CCW coil arrangement on the output secondary coil.  Or use a large pointed wire that would arc to an insulated copper plate that went thru the load and into a solid grounding wire.  Like TK used in his large Turkey setup.  The current amplifier.  I could explain it better but I have very little left brain capability and can't remember shit.  Anyways If you would update your old Akula device with the TV yoke and get rid of that thing.  I don't know why he used it in the first place.  I am going to try the 30 watt Akula version, but I can't read or understand all of the component values.  Maybe if XName did it, he can let us know a little more about the values needed.  Anyways good luck to everyone and I hope an American will replicate one of his devices.  I believe there are 2 guys from russia who have done so.
This is just what I think could work to replace the mechanical switching device.  So don't take it as factual working circuit.  I did find it interesting that I used this circuit as a good guide and it is also used in one of Zilanos possible circuits.  I don't think that she made it, but she might have.  It comes in a PDF of her works.
Yea I agree totally with cheappowers statement about dumb people who get joy from faking out people with their videos. The worst I have seen are from those weird Indians(not American), like the surge strip that is plugged into itself and started with a pizeo lighter ignitor.  I mean come on, who would ever believe that??
Anyways Cheappower if you want to prove that the TPU is real, try combining waves on seperate coils that combine into one and create impulse waves.  Coil modulation..  I am sure that is what bruce is doing.  The Kick is an Impulse spike.  I dont have the equipment or knowledge of waves to produce that kind of work, but it is just another way of getting energy from spin spin of the nucleus.  I think it works the same way as TK's does, just done differently with modulation of waves to produce the impulse instead of just creating the impulse spike to begin with.  The single impulse travels down the wire in one direction and combined with the Earths magnetic field it turns the nucleus up to the higher energy state position and spins it and after the T1 relaxation period it gets hit again and spins back up releasing energy.  But the few factors make it hard to tune the device.  Like wire type, which can change the T1 relaxation time depending on if its old wire, steel wire, tinned copper, new copper ect...  So the circuit has to be made to make those adjustments automatically.
rapbbit
Quote from: magpwr on March 03, 2014, 08:07:12 AM
Someone was kind enough to post a Russian backup video of  Don Smith video part 8 in youtube,couple of days back.This video of Don Smith which i have not seen before in youtube.
I'm able to  "reverse engineer Don smith device at every point" merely by looking at Don Smith video twice or thrice.Starting from 24min...35min.
basic hints: hv diode 20kv..25kv ,hv cap bank 8000uf 2000volts each x 4 and etc
http://www.youtube.com/watch?v=cQkYAh8Qgb4
The funny thing if you compare any other "Don smith replication video" in youtube if you got the time is that everyone whom replicate Don smith device choose to do it their own way.I'm just being honest
"Trying to be smarter than the creator in this case Don Smith"
I hope you understand my justification on why i still choose to continue working on finding "Fool's Gold"   :D
i don't understand why smith said 4× 2000V capacitor in series giving 8000V,but in the device,the 4 capacitor is connect in parallel,why?
energia9
im sick of fakers so you are.
the question is allways, why?  why...  just whyyyy???    why is it good for you to fool others. im disgusted by you for tricking other people... why is this good for you????  tell me.  why in heaven is this good for you?   i feel sorry for you.
