0 Members and 142 Guests are viewing this topic.
magpwr
Quote from: grizli on March 09, 2014, 08:35:45 AM
Please explain I dont understand Russian
hi grizil,
I am not able to understand Russian at all but i am able to co relate and associate all the 1000+++ images i have seen in my head which assist me a lot.
I have attached just 3 piece of information for you or anyone related to the useful video related to Don smith replication/variation."How to power motor from Don smith replication"
In layman terms straight to the point- the objective of the "Don smith replication\variation" circuit is  to bring down high frequency to lower useable frequency which allow the motor to run.
Please don't ask me more as i merely know how to make it work without fully knowing "why" it works.I'm no Phd holder to provide the theories.  :)
http://www.sengpielaudio.com/calculator-XLC.htm
Refer to attached "stepdown" circuit
1)Apply the capacitor value 4700x2 =9400 (uf) and 1 mh (In the circuit it shows 3.5mH which is a variable inductor max 3.5mH,I just use 1mh for easy demo)
   Use the provided XLC calculator link and insert 9400 for capacitor and 1mH for inductor.Then click on calculate.The result would be 51.91HZ .
Remember common mains powered motor is design to works between 50...60Hz. :D
There's the answer you need. :D :D :D
I hope you do have knowledge in electronics to understand my provided information.
It looks fake earlier on only because you didn't know how it works.The confusion is the non A/C support capacitors-4700uf.It's not a efficient design-works on positive 1/2 cycle.
People would prefer to go for self runner without the motor as a proof."That video is still a work in progress"
DilJalaay
@magpwr, and all,
thanks for the post.
i am really surprice why people waste there time and money for replicating a hidden black box like thing of TK, he does not show any thing to us, always hide his invention in box, cables and circuit boards. All we know that he do that to hide his very simple invention.
But instead why not people work on the system, which are proven to work. Which is all open on board, nice close shots, all components values are know, circuit diagram is perfect with complete details and tutorial videos on how the device work... and it is what Dynatron given to us, as clear as open as a sunny shiny day.
Why then people go for things with no clues and any details?
What i find Dynatron is a true and faithful person, he gave us every thing without any penny.
His work it totally based on DonSmith work, a little bit different. They both are doing what Gray done it.
What they did actually is generating and Cold electricity of N.Tesla.. and using them.
What is common in both Dynaton and Gray(Efficient Power supply for Induction motor), they both run motor by this cold electricity.
And Don lighting bulbs.
Cheers,
D.J
Acca
 Eternally burning torch without batteries (from Ruslan Kulabuhov) last week...
Here is a russian description of the 30 W device of Akula0083 in the video clip plus a duplication of that device last week..
I t looks like russians are making build...
I have re attached diagrams for the posted diagrams of Akula0083
Overview flashlight Sharks [PART 1]
http://www.youtube.com/watch?v=4C4vzlW0Oxw&list=UU8wodvsxDbBQxihf_ilGIuA
Follow the akula0083 for site realstrannik.ru
по следам akula0083 для сайта realstrannik.ru
http://www.youtube.com/watch?v=OOG6YQ_6K6k&list=UU8wodvsxDbBQxihf_ilGIuA
Acca...
jbignes5
Quote from: DilJalaay on March 09, 2014, 12:58:14 PM
@magpwr, and all,
Cheers,
D.J
I would get away from the cold electricity angle. Tesla said that it exhibited many side effects based on the period of the impulse and it's strength or magnitude of the period. These effects were among many, Hot and cold breezes, spontaneous light and all of the effects he saw on the coils around his lab. In particular was the effects seen from his conical coils. It seems that if you try to compress this field it will speed up and eject away like water or gases do. In fact he was particularly interested in the discharge from the eld of the conical coil in this new field. They hissed and a reverse cone of plasma formed on the end of the coil YET Tesla could not find any current running through the coil. It seemed to be a surface and outward effect from that surface.
Impulse currents are very different than the traditional current we all know. This is where we should be looking. Impulse technology utilizes the inertia associated with the medium of space. Once you get that going it will power itself especially if you have a clear in and out for the tap to the flow of the medium.
In my own experience Voltage itself can initiate a movement or to be very clear a 3d movement of the medium. Usually the shape of the affected medium will be round or of that nature like torus. Now the movement is very simple. All space has a density of the medium in it. Since space is so vast it tends to be very uniform across and space you examine. There are additional rules that need to be applied for special cases. One being matter and the density  of that matter that tries to displace the medium. Yes the medium can be displaced by matter. The medium extends all the way below sub atomic particles and since the medium doesn't like to be displaced it pushes back or forms an increase of the springiness between matter or forms pressure. where there is little matter there is a huge density of the medium.  And likewise where there is a huge collection of matter there is the same density of the medium just compacted by the displacement of the medium.
When the medium is rich and contiguous any object thrown into that space will exhibit outer space like effects like all heat being sucked out of the object and such. When the medium is pressurized it must keep the same value as the surrounding medium so this is where all the excess energy is. This pressure is seen as heat and electrical potential based on the type of matter the medium is compressing.
One experiment that I can claim as leading me to this is the crystal batteries. My own work on this subject has been exhaustive to the point that I think I know where these batteried get their power from. Yes the standing potential of the matter is a great determiner of the power of the cell. And there are many aspects to how it gets conduction throughout the battery. Different crystalline material give vastly different results but I was able to extract energy from a glass jar with a spiral aluminum wire going into the jar and a graphite center electrode. If it was due to heating then wouldn't the glass tend to radiate most of the heat away? Yet the glass jar battery was my best ever. The aluminum when treated with borax solution and baked on became super shiny and showed no signs of corrosion even after I dissected the cell to check for corrosion. There was no sign of corrosion at all.
Something other then heat was at the center of this experiment. One thing I asked was what gave it it's standing potential and that lead me to space itself and then it wasn't hard to jump to Tesla's concepts of space, matter and of the medium space is made of.
It is right in front of our eyes and we take it for granted every single second of every single day. Space.
a.king21
http://theflowofperceptions.blogspot.co.uk/2014/03/benjamin-fulford-march-10-2014-nazis.html
"The WDS said that free energy technology would only
be allowed a first for projects the current oil business model cannot
carry out, such as turning deserts green with desalinated sea water and
heating up the arctic and Antarctic. Oil would then be phased out
gradually as the oil industry shifted to the business of creating new
eco-systems. The oil industry people asked that they be allowed to
continue expanding their hydrocarbon business using natural gas and this
was considered a viable option"
