0 Members and 115 Guests are viewing this topic.
From other Planet
I watched the chinese Video: https://www.youtube.com/watch?v=vowN5BFGW1c again and wanted to share some thoughts about it: (all IMHO)
-the HV diodes are below the long strip with the terminals, that go to big HV Cap Bank and the L2 coils
-the 3 small ferrites above front PCB are transformers, with 2 OUTPUT coils each, to galvanically isolate the gate driving circuits of the MOSFETS from each other, otherwise it wasnt possible to connect them in series
- what im unsure about is the big yellow cylinder and the small white thing that are in series with the L1 coil. The small white I believe is a diode. This would match statement of elementSix "Unidirectional currents are also a must part of getting more out than in". What do you think?
Its sad the quality of video is so low and he doesnt show any measurements, but im not even interested about that much. Im interested in how to drive the Don Smith and similar devices with semiconductor technology
lost_bro
Quote from: From other Planet on March 17, 2014, 02:35:11 PM
Hello From other Planet
OK, yellow small thing is a 10KV capacitor;
Big yellow cylinder is a 100 turn coil;
Of course it is DC current because the Half-bridge DC-DC converter has rectified output:  The series MOSFETs are switching DC not AC.
But, when in resonance, the waveform is AC passing thru the L1 coil.
and Yes, the three green transformers are GDT (gate drive transformers) use to  galvanically isolate the Six CREE MOSFETS.
take care, peace
lost_bro
I was told by the developer that the device in the video is consuming about 2 amps @ 12 VDC so about 24watts of power to run over 1000watts of incandescent lamps.
Running SS seems to economize the power input over that of conventional SG.  Tesla himself commented about this in the Colorado Springs Notes.
take care, peace
lost_bro
forest
lost_bro
How would you implement a step down from output to feed back input in this case ? I watched Igor (Mopozco) videos and he used current transformer wound on ferrite ring but stated it overheat after short time.
From other Planet
Thank u for the information. But i still have doubts about the small yellow/white thing being a cap. If its a cap it would be charged to supply voltage after short time, then never again discharge and after some microseconds all oscillations would cease, no?
Maybe half of MOSFETS are used to charge it, other half used to discharge it in L1? hard to see the connections around the PCB boards in the video...
lost_bro
Quote from: From other Planet on March 17, 2014, 05:20:26 PM
Hello From other Planet:
The developer stated that it is a 10KV capacitor, not sure of the pf rating;
I have capacitors here just like the one in the picture, so I have no reason to doubt the developer;
As you know, the Series MOSFET string will function just like a SG, so as the MOSFETs are switched in frequency with the resonance of L1/ L2 and other components in system, the waves respond accordingly;
This video was NOT made for YouTube and was put on YouTube only after the original website and info. was removed in China;
This video was made by a small group of researchers who mentioned that they spent over two years working on this.
I have no reason to doubt the developer and do believe that this is one of the few REAL replications of DonSmith:
I have spent since last year gathering parts and reverse engineering the individuals circuits of this replication....
I was lucky to have communicated with the developer before the disappearance of him and all the information.
Take care, peace
lost_bro
[/b]
