0 Members and 140 Guests are viewing this topic.
captainkt
@gyulasun, thanks for that although the voltages all look very low. The flyback is 40,000V so I do not know how they would stand up or function, suppose I could try, also no adjustment with them.
Keith
gyulasun
From other Planet
From my experience, the surge arresters also tend to stop working/change behaviour after a while. Think they are available in different "strengths". Lifetime probably also depends on strain...
elementSix
Resonance with medium.   Now what would that serve??  A great deal I would say.
How it works
The capacitor. There are only a few basic building blocks of electrical circuitry. The capacitor is one of them. Tesla didn't invent it, it had been around for some time, arguably for millennia, but he did improve upon it in three of his patents. Also called condenser, the common capacitor is just a sandwich of conductive and nonconductive layers that serves the purpose of storing electrical charge. The simplest capacitor has just two conductive sheets separated by a single sheet of insulation. In the capacitor shown, the conductive elements are two metal plates.
The insulation between them is oil. In the official vocabulary, the plates are indeed called plates and the insulative layer (oil, glass, mica, or whatever) is called the dielectric. Connect the two terminals of a capacitor into a circuit where there is plus-minus electrical potential, and charge builds on the plates, positive on one, negative on the other. Let this charge build for a while, and then connect the two plates through some resistance, a coil, say, and the capacitor discharges very suddenly. Tesla said, The explosion of dynamite is only the breath of a consumptive compared with its discharge. He went on to say that the capacitor is the means of producing the strongest current, the highest electrical pressure, the greatest commotion in the medium.
The capacitor's discharge is not necessarily a single event. If it discharges into a suitable resistance, there is a rush of current outward, then back again, as if it were bouncing off the resistance, then out, and back and so forth until it peters out. The discharge is oscillatory, a vibration. The vibration can be sustained by recharging the capacitor at appropriate intervals. When Tesla talks of the capacitor's discharge causing commotion in the medium, he means a vibration or mix of vibrations. The character of this vibration is determined in part by the capacity of the capacitor, that is, how much charge it will hold. This is a function of it size, the distance between plates, and the composition of the dielectric. Upon discharge there would be, typically, a fundamental vibration, some harmonics, and perhaps other commotion, maybe musical, maybe not. Additional circuitry can tame the vibration to a pure tone.
The medium
When Tesla speaks of commotion in the medium, what is the medium? In Tesla's time it was an article of faith that there existed a unified field that permeated all being called the ether. The ether as the electric medium still is an article of faith in some circles, but in official science its existence is presumed to have been disproved in the laboratory. Nevertheless, this conviction about an ether ran very deep, not only among scientists but among all thinkers, until only about forty-some years ago when particle theory, E=MC2, and, finally Hiroshima firmly established the new faith. Tesla said the electron did not exist.
The materialistic concept of these little particles running through conductors is alien to Tesla electric theory. Here is the Quaker writer Rufus Jones on the ether in 1920: An intangible substance which we call ether - luminiferous (light-bearing) aether - fills all space, even the space occupied by visible objects, and this ether which is capable of amazing vibrations, billions of times a second, is set vibrating at different velocities by different objects. These vibrations bombard the minute rods of the retina... It is responsible also for all the immensely varied phenomena of electricity, probably, too of cohesion and gravitation...
The dynamo and the other electrical mechanisms, which we have invented do not make or create electricity. They merely let it come through, showing itself now as light, now as heat, now again as motive power. But always it was there before, unnoted, merely potential, and yet a vast surrounding ocean of energy there behind, ready to break into active operation when the medium was at hand for it. Jones, who was not a scientist but a religious thinker and communicator, was making a point about the nearness of God's power and could do so by invoking the physics of his time. This would be difficult using the Einsteinian physics in fashion today, which W. Gordon Allen has called atheistic science.
Although the ether is intangible, it is assumed to have elastic properties, so that Tesla can say a circuit with a large capacity behaves as a slack spring, whereas one with a small capacity acts as a stiff spring vibrating more vigorously. This elastic character of the ether, which you experience palpably when you play with a pair of magnets, is due to the medium's lust for equilibrium. Distorted by electrical charge (or by magnetism or by the gravity of a material body), the ether seeks to restore a perfect balance between the polarities of positive-negative, plus/minus, yang/yin.
Voltage is the measure of ether strain or imbalance, called potential difference, or just potential. Balance is not restored from this strained condition in one swing-back. As we have seen with the capacitor, the disturbed electric medium, like a plucked guitar string, over-swings the centerline of equilibrium to one side, then to the other, again and again, and this we know as vibration. In this way of looking at nature, vibration is energy; energy is vibration. So you could say that the commotion in the medium caused by the capacitors discharge is energy itself.
Thus, you can speak of the capacitor as an energy magnifier. Even though a feeble potential may charge it, the sudden blast of the capacitor's release plucks the medium mightily. The capacitor is common in modern circuitry, but Tesla used it with much greater emphasis on its capability as an energy magnifier and on a scale almost unheard of today. It's difficult to find commercial capacitors that meet Tesla specifications. Builders of tesla coils and other high-voltage devices usually must construct their own capacitors. Fortunately, this can be done using readily available materials.
The spark gap: A simple way to discharge a capacitor is through a spark gap. The spark-gap oscillator is just a capacitor firing into a circuit load (lamps or whatever) through the spark gap. The opening between the spark-gap electrodes determines when the capacitor will fire. This setting is one determinant of the frequency of the circuit.
The others are capacity and the reactance, or bounce characteristics, of the load. The potential needed to bridge the gap is in the tens of thousands of volts. It takes a potential of about 20,000 volts to break down the resistance of just a quarter of an inch of air. The gap doesn't necessarily have to be air. Tesla has referred to a gap consisting of a film of insulation. A spark gap is a switching device, a semiconductor in fact. But the spark gap is problematic, particularly the common two-electrode air-gap version. Heating and ionizing of the air cause irregularities in conduction and premature firing.
This arcing must be quenched. It can be to a great degree by using a series of small gaps instead of one larger one, or by using a rotary gap. Tesla also immersed the gap in flowing oil, used an air blowout, and even found that a magnetic field helps to quench. For the gap Tesla substituted high-speed rotary switches, which he called circuit controllers. One has a rotor that dips into a pool of mercury, and another uses mercury jets to make contact. You can operate a spark gap without a capacitor by connecting it directly to a source of sufficient voltage.
This is, of course, how our automotive spark plugs work, directly off the coil. (The capacitor in that circuit is used to juice the ignition coil primary.) The auto distributor, incidentally, is a rotary gap, pure Tesla. Early radio amateurs used spark-gap oscillators as transmitters. The capacitor was, more often than not, left out of the circuit, but with it the transmitter could create a greater commotion in the medium.
https://altered-states.net/barry/tesla/
Sorry for those who are waiting on me to get my shit together.   Looks like I have to make another capacitor.  This time I am making a 2 plate adjustable capacitor so I can fine tune the impulse.    So it can bounce back in fourth in the Medium more easily and allow buildup of excess potential..
balphom
elementsix i believe you have a clear understanding and a lot of Tesla material. in his patent no.787 412 the art of transmitting electrical energy through the natural medium. there is a part he is saying " third. the most essential requirement is however, that irrespective of frequency the wave or wave train should continue for a interval of time .......................... pliz can you explain what he ment in the whole paragraph and how to put it in practice.
