0 Members and 120 Guests are viewing this topic.
Zeitmaschine
Quote from: jbignes5 on March 30, 2014, 10:52:10 AM
Tesla's wireless system did not use Hertzian waves, Period.
That implies we must not look further for Tesla's wireless system because Stepanov, Kapanadze and Barbosa do use Hertzian waves by means of ordinary transformer coils.
jbignes5
No in fact most of these guys use rewound coils on the transformers.
Also TK used spark gaps in most of his devices as well and that is the point of this thread. TK not the other guys. One case of the spark gaps is sooo blatant even you should be able to see it... I also firmly believe that where there wasn't a in your face spark gap it was hidden inside boxes that he used extensively. Spark gaps imply a Tesla impulse system.
Your comment is so strange it makes me wonder why you are fighting sooo hard EVEN when the Inventor Tells You himself where he got the information to build his stuff. Wow
This thread is about TK and no others.
Anyways my response to the wireless system was to clarify the wrongs in the information. Yes it has parallels and yes it shares basic fundamentals to both systems.
As to the exact circuitry I leave it up to the brainiacs who think they know from pictures and from general block diagrams of what the exact circuitry is.
You guys wonder why TK isn't here himself explaining this. Well let me clue you in. Looking over the 1000's of pages here, would you come to such a hostile place and teach people about your circuitry with all the hostile crap being shown here? I wouldn't. And is the main reason I stopped posting to much to this thread. Too much junk and not enough real experimenting going on here.
pix
In my opinion Stepanov is using only one side of transformer windings and capacitors for resonance of tank  LC circuit, and grabs reactive energy with the help of current transformers.
That's my 3 cents.
Regards,
Pix
DilJalaay
Quote from: stupify12 on March 30, 2014, 12:45:04 PM
Everything you cited is correct and I understand perfectly that Tesla Transceiver are not the same with Hertzian waves, the energy travels/propagate within the Ground/Earth.
Thanks for your great info and detailed, happy to have some people that really understand how a Tesla Transceiver works.
On my post above, once you disconnect one of the GROUND/EARTH terminal the load= bulb wont light even a little, if everything meets the novel design of the great Nikola Tesla, any load, any secondary coils as much as u like will only boost the performance of such device. That transformer above wanted a overloaded scenario, it really wants to have a SHORTED circuit=close loop coil on the secondary to x2 its power output on the Load. The Tesla 1 wire transmission is the prototype to the Tesla Rarefied Gas Transmission then to the Wireless Transmission of Energy it is just improvements of simple device which works solely on energy propagation on the Ground.
Meow.. ;D ;D :P
Good day,
Thanks for the great post.
Is there any possibility or modification for this circuit to use only one real earth???
As many experimenter including me can hardly arrange only one earth(water supply pipe) to do our experiments.
Help from the experts are highly appreciated.
Kind Regards,
D.J
stupify12
Attention: When the spark gap switch is remove on the device, the device will not output power and cant even light a bulb. Yes it needs a SPARK GAP to observe a Radiant Energy Phenomenon on such device.  Once you have found the Radiant Energy Phenomenon, anything you put coils, loads, close loop coils,cap-coils, cap plates.. are neglected by such propagation of Energy, anything on its path are being charged rapidly.
On Tesla patent 1 wire Electrical Transformer, please put the SPARK GAP on the HV 1 wire, it could be on the Center of the wire between the Two Transformer, or The spark gap could be put near to the ground of the 2nd Transformer= because the HV primary of the 2nd Transformer is the maximum potential on Tesla's device.
Reminder: Tesla Coil is different from Tesla Transformer, Everyone here only knows the so called Tesla Coil. You need to research Tesla Electrical Transformer not the power supply so called Tesla COIL. ;D ;D ;D
Meow   ;D ;D Re uploaded. The circuit used: http://webpages.charter.net/dawill/tmoranwms/Elec_IndHeat1.html
Quote from: jbignes5 on March 31, 2014, 01:34:36 PM
