0 Members and 326 Guests are viewing this topic.
captainkt
@jeg,What is lower potential sink? do I want it or should I avoid it. If I want it how do I get it, and are we talking 24,240, 2400volts as compared to a flyback voltage of 24,000volts, plain language please.
Keith
stivep
Jeg
Quote from: captainkt on April 22, 2014, 03:03:06 PM
Keith
Keith
It is a universal law that energy always flow from high potentials to low. If two tanks with water are connected, then when you open the valve the water flows from the tank with the higher level of water to the tank with the lower level of water. This is the basic principle. As elementsix Leedskalnin and many others said, we are using the wrong side of electricity and that means that we use to work our electric circuits with positive potentials which are above the ground or surrounding environment  level. Just that by itself, is a waste of energy escaping from the wires and components to the surroundings. If we turn our design philosophy as to use potentials lower than the surrounding environment, then the process is reversed. Energy escapes from the environment and fills  our circuits up through the wires and components. This is the so called ENERGY SINK. There are no losses this way. To explain it better lets say that a circuit works at 24v dc positive voltage. That means that every component in this circuit see a potential difference of +24v comparing to ground. If we just change the pwr supply to -24v compare to ground then what will happen? It is just that the process will be reversed. This knowledge by itself can change everything. Look for example the kapanadje replication of naudin's. Notice how is feeding the primary with negative pulses... Some used to say that the higher the pulse the better the gain. It is just that no one mentioned that we speak about negative pulses.
Cap-Z-ro
Quote from: forest on April 22, 2014, 03:54:05 AM
Excuse me but I think you didn't follow the reality... most of inventors were not BOLD and POWERFULL RICH CHAPS bored of theirs life, wanting to do something extraordinary. Look, community do not support them , they are not honored , they are not living in safe situation having all requested means to continue working on improving device. The most they could expect is a patent and a kicstarter project , only if their idea is not a threat to the powerfull lobby...
What is Tariel doing now ? did he got a solid position in the factory producing his devices in commercial manner (for usefulness of community) ? did he got a shares stock in bussiness on every produced device ?  or maybe they are trying to rip him off and continue research without him ?
How do you know what is better to do ?
/excerpt from the book "The Te of Piglet" byBenjamin Hoff  /
How can I possibly address what you said when it does not relate what I said ?
I suggest a re-read.
Regards...
Wesley Translate's Akula video #16: Akula's TPU part 5
https://www.youtube.com/watch?v=Lpx1SJdXnmo&feature=youtu.be
Wesley
forest
Jeg
This is all true, except missing one important factor. Try to connect a load across two (!) batteries terminal, like for example take 9V battery and 12V battery. Then try to connect bulb between 9V negative and 12V negative. What do you expect ? According to claim 12V negative terminal is more negative and there should be current flow ... ???
