0 Members and 196 Guests are viewing this topic.
Zeitmaschine
Who can put together that jigsaw puzzle the right way round?
Who can draw in the proper connections between all these electric components?
andrea76
Quote from: stivep on April 24, 2014, 08:05:40 PM
https://www.youtube.com/watch?v=mG_FsBn2qxk
Wesleys News Overunity com presents :
Free Energy Device - Akula 1 KWatt Unit - no fuel needed
Wesley
where did the white wire??
elementSix
Ok for those who want to attempt to make this device, you will need to make a capacitor.   This must be a Parallel Plate Oil Filled Adjustable capacitor.  Use boiled out oil and just make it like tesla did.  You will use this to tune your coil setup.  The capacitor must be in symmetrical arrangement with the discharge circuit.  And the closer to the primary, the better.  The Current amplifier can be a number of things.   It can be a second secondary coil that if the exact mirror of the first secondary coil that is up close to the primary.  The 2nd secondary can be in series with the first.  I used a insulated plate and a nail at the end of my secondary that arced over to the grounded plate.  It was lame so I just added another secondary after reading Eric Dollards, condensed intro.  See link below for this.  If you have not read it,  read it.  Its not long.
http://www.tuks.nl/pdf/Eric_Dollard_Document_Collection/Condensed%20intro%20to%20Tesla%20Transformers%20by%20Eric%20Dollard.pdf
another link in case that one is down
  http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&ved=0CDYQFjAC&url=http%3A%2F%2Fstatic.socialgo.com%2Fcache%2F246062%2Fassets%2Ffiles%2F4eaff249c31aa-246062-Eric%2520Dollard%2520%2520Condensed%2520intro%2520to%2520Tesla%2520Transformers.pdf&ei=FBJfU-bBIOfl2AWazICQBg&usg=AFQjCNEBJcIMDGO19FbxlB62WLijONErSw&bvm=bv.65397613,d.b2I
Tesla adjustable condenser....
http://www.teslauniverse.com/nikola-tesla-patents-464,667-electrical-condenser
stivep
PLEASE JUST READ IT
I'm not trying to waste my time here but make you  to gain something from me and me gaining something from you.
I still try to believe that this forum is not entirely  made out of only opportunists with flat brains, stupid idiots, looking for easy money, and/or spies working  for money as well.
The main difference is:
I do not care if I make money on it
But I care that big corporations will not be able to patent anything I say here as it was already said by me or by you as well.
But patents are the lacks on the door  to the  freedom of energy.
If I ever  submit patent  is to be able to control "big guys" only.
Let them to know how is to be one of 99%
statement: Everything said here can not be patented by you and by me as well as it becomes general  knowledge one has said and  once is said.
Posted by: elementSix
QuoteOk for those who want to attempt to make this device, you will need to make a capacitor.   This must be a Parallel Plate Oil Filled Adjustable capacitor.  Use boiled out oil and just make it like tesla did.  You will use this to tune your coil setup.  The capacitor must be in symmetrical arrangement with the discharge circuit
That makes TK hydroelectric generator as the biggest problem he has had was heat.
1-heat- aquarium video
2- presentation of rotating disc in the warehouse in Georgia with the presence of electrician hired by  another Georgian "investor"- (government rep)
advantages:
1. TK generator when enclosed in the box is not visible to human eye.
2. heat can be used to drive sterling motor or  pump. But for what? it is the electricity is there ready to be used in the first form.
well. heat is the  loss so how about to use it as well.
3.Discharge might not be in form of spark. The most important is energy level difference.( charge difference at first)
  so he was playing with HV everywhere in any device he made. (e.g. device  presented to me was using HV generator from  gas stove. and there was no spark- the potential difference was created in gas spark generator by itself On-OFF on demand, than delivered to coaxial cable acting as  capacitor.
So only 2x100W explains that above that level there is significant  heat production.)
Disadvantages:
Heat was main destroying factor of:
1- keying electronic components
2- ionization stabilizer embedded in his device
Now it is the time for some golden words:
Note: would you mind to exclude the word   "..."  in all text
      opinion
My "speculation" is that  delivery of ionizing source such as small amount of Am241,
( however it is mostly Alpha- not so good but not bad at all.)
or
Cs-137 at legally allowed proportions  "may" (Note: would you mind to exclude the word    "..."  in all text ) make the trick.
So how it "may" work
lets look at any given scenario of TK device.
a- spark gap
b- no spark gap
What would be the common factor to that I said above - and  is solely  the  property of an  insulator?
let's list some of them:
-insulation permeability
-insulation ionization state
and from that we derive resistance and impedance ( 3D dependency of size,shape- not important for now)
but because we are not concentrating our-self on DC  and we focus on AC mostly
We might skip resistance completely.
However we might  need pure resistive reactance as part of impedance  equation.
or say as impedance component only.
As far as:
- inductive reactance
and
- capacitive reactance
Both depends  from  frequency of oscillation.
Both of them vanish in resonance as if they do not exist any longer.
Properties of resonant circuit:
- for parallel only for frequency of resonance impedance is high and it has its own bandwidth.
- for series   only for frequency of resonance impedance is low( practically nonexistent) and it has its own bandwidth.
That applies to insulators as well.
Air is  an insulator but ceramic and Teflon  is insulator as well.
It works for static electricity as insulator. So there  we go. We have  charge potential.
It does not work for RF and it is mostly invisible for impedance properties as electric and magnetic component of electromagnetic field  do not see it.
Ionization source, might have problem with insulators only as to gain access to: accessible  medium for ionization ( air) or particles
The higher the charge difference, the less ionization is needed, as charge by itself acts as ionizator.
and than we HAVE PROBLEM WITH INSULATOR BREAK- avalanche of electrons.
So we need to help to get as much as we can controllable ionization at relatively  low charge difference.
GOT IT
at the given potential difference of  given physical properties
sustainability of ionization uses energy that is not to  be paid for:
no spark+ no impulse=0                       where  0 stays for -no action (process in motion)
no spark= no impulse=0
spark= impulse=1                                where 1 stays for action (process in motion)
so what makes energy level insufficient for  spark
LACK OF SUFFICIENT CONTROLLABLE IONIZATION~!!!!!!!!!
Ionizing stabilizer  is the one that makes frequency stabilization.
That is for now I think I should make   video for it
Wesley
PS: thanks to all of you for emotional support and solidarity. I need you all.
I'm thinker and that is what I do the best
You do the rest ...........
I love to fallow the path of invention and after is made there is not to much fun any-longer..
Just business as usual....... for many of you.
havuhung
Dear stivep,
Thanks a lot for your video clips.
Regards.
