0 Members and 125 Guests are viewing this topic.
Zeitmaschine
Back to the basics. :)
Here are some tests and measurements of mine. A 12V battery is connected to an inverter and a HV transformer.
The inverter has an output voltage of 227.2V 50Hz sine wave. Connecting it to the HV side of the transformer (step-down) gives 19.04V output. That means 19.04V into 227.2V equals 11.93 - that is the primary to secondary voltage ratio of that transformer.
Connecting the inverter to that transformer the other way round (step-up) one has 223.8V times 11.93 equals 2670V - that is the high voltage output of that transformer.
When the high voltage coil is shorted via a 1MOhm resistor then one has 1MOhm into 2670V equals 0.00267A that means 2.67mA times 2670V equals 7.13W - that is the dissipation power of the 1MOhm resistor. 7.13W at 12V equals 0.594A - that is the additional load on the battery when the HV coil is shorted through the 1MOhm resistor.
The idle current (open HV coil) in the 12V circuit is 0.905A the loaded current (connected 1MOhm resistor) is 1,499A (theoretically) the effective measured value is 1.462A (seems the high voltage goes down a bit due to the 1MOhm load).
Those calculation and measurements are proof that the ammeter in the 12V circuit shows the correct value.
Now a strange thing happens when one end of the HV coil is connected to an antenna and the other end sparks to ground. Although sparking means there is some current going (and/or coming) from the ground for sure, the ammeter (multimeter not clamp meter) sticks at the value of 0.905A for the 12V circuit. An ammeter (multimeter not clamp meter) put in the ground line shows current values up to 3mA while sparking. The smaller the gap the higher the displayed current.
Since the HV is 50Hz the spark also fires with 50Hz (in the ideal case). This leads to the assumption that the spark should be replaced by a 50Hz resonant LC circuit in order to catch the energy from ground which otherwise gets wasted in the spark.
Conclusion: If there is no additional current flowing in the 12V circuit then the current which creates the sparking to ground has to come from the ground itself. The sparking is created by free electrons from Earth. It gives maybe one watt of power (light, heat, sound of the spark) for free. But that's without any resonance of course.
Moreover the ground can be replaced by a metallic object. So we have a metallic object on one end and an antenna on the other end. That reminds me a) of Tesla's electric car, b) of the Moray device (both worked with antennas) and c) of Kapanadze's aquarium II device which grounding braid is not connected to a grounded water pipe but strangely to a non-conductive concrete slab.
Further ideas on this are welcome.
Acca
 Some things about NON Conductive ferrite cores and a Weslay reply !!!
Quote       Said : magpwr:
"I have read this somewhere in internet it looks some of the old soviet made ferrite core are irradiated as part of the manufacturing process."Sorry I am unable to validate if this is true".
I am just thinking if this irradiation process do play a important "OU" role from the particular Russian Yoke to this recent ferrite pot core".
Quote       Said  Stefan. H.:
"We have here an audio frequency of about 6 to 10 Khz at play probably resonating the core in this frequency range..You still can hear it... So no Ghz are required...
Maybe via the spikes higher harmonics, but I guess this will not go into the Ghz range...
Although it will probably depend what ferrite core material you are using...
I wonder why TK´s core has such a low electrical resistance.
Normally Ferrite cores have much higher ohmical resistances....
We surely don´t want to have eddy currents inside the cores..."
Well done Weslay !! it's thorium that I am using 2% from TIG welder tips (gamma).  To produce an invisible electro-static ark as in this clip shown..  (radioactivity used to maintain ionization potential)..
The center of the device has to have a NON-Conductive iron (electrical core) that is "magnetic."   (contradiction,  >>>iron is conductive and magnetic,
1Ghz is one billion CPS, "spin waves...
Acca..
Quote     Said: Weslay:
"My "speculation" is that  delivery of ionizing source such as small amount of Am241,
( however it is mostly Alpha- not so good but not bad at all.)
or
Cs-137 at legally allowed proportions  "may" (Note: would you mind to exclude the word    "..."  in all text ) make the trick.
So how it "may" work
lets look at any given scenario of TK device.
a- spark gap
b- no spark gap
What would be the common factor to that I said above - and  is solely  the  property of an  insulator?
so what makes energy level insufficient for  spark
  LACK OF SUFFICIENT CONTROLLABLE IONIZATION~!!!!!!!!!
Ionizing stabilizer  is the one that makes frequency stabilization.
That is for now I think I should make   video for it"
(sorry I just got it out !!) just for you and TK....
MY CLIP's !!
http://youtu.be/aWtc90FfawA
https://www.youtube.com/watch?v=sTgXY0Zs2_4
link to spin waves:
http://www.ioffe.ru/optics/SW2013/Acca.. [/font]
stupify12
Almost there dude  ;D ;D.
What will you  to do with the HV output of this device to be transformed into a useful current like 220v or 12v? ::)  That set up need to be Step Down to transformed the High Potential(High Voltage) with lesser quantity(Amperage) into a Lesser Potential and Greater Quantity(Amperage).
All of your findings and results are correct. About the Resonant Circuit well we are looking for the Efficiency. I have always showed you my findings about this. The Stepanov and Kanapadze works on the same concept which actually I have already posted here but no one is interested.
Keep up the good work. You need higher Frequency Resonance then the Spark Gap should fire 50times per second on your country.  Hell yeah.. ;D ;D
Meow.   :o :o
Quote from: Zeitmaschine on April 29, 2014, 02:25:13 PM
Zeitmaschine
Quote from: stupify12 on April 30, 2014, 12:26:36 AM
You can provide a drawing perhaps? :P
Quote from: stupify12 on March 06, 2014, 07:53:16 PM
What if I tell you that the TPU and Tariesl device runs solely on the working principle of Nikola Tesla. The working principle which those device was running is from the prototype of the Tesla Magnifier Transmitter.
Before Cellphone was invented, there was Wired Telephone right? Before it evolves to Wireless Transmission of Energy it needs go be invented in a Wired fashion right?
It is so simple that you will laugh. HAHAHAHAHAHA   ;D ;D ;D
Transceiver  is the correct term for that machine which Tesla invented. The Transmitter will function as transmitter and receiver. The Receiver will function as transmitter and Receiver it is because the
Two Tuned Circuit are identical.
It is commonly called AMPLIFYING COIL why because it does amplify its own oscillation of energy, that is because it function as a Auto-transformer that its energy is being bounce back and forth between the Two Transformer. The Kicking Coil they say is just a inducer for that Amplifying Coil to start its function.
The main hint here is TWO TRANSFORMER which is configured away from each other and function as
Auto Transformer in operation. ;D ;D ;D ;D
Meow ;D ;D
So then. We have a high voltage transformer and a second transformer that is used as choke and a capacitor. All in 3-phase. I'm sure 3-phase is not needed in case of the two transformers. But I'm not sure about the 3-phase capacitor. Do we need one single capacitor or two or even three capacitors?
The two transformers must be in resonance with each other. Does that mean the high voltage transformer and the choke must have the same inductance in order to resonate with one capacitor? That's a bit difficult to get I think. But maybe that's the key just because of its difficulty. ???
Zeitmaschine
Auto-transformer? Something like that?
Problem: I can't see a spark gap in any of the Stepanov videos. Also I can't see a spark gap replacement (transistors or thyristors) in the Stepanov workshop video.
