0 Members and 285 Guests are viewing this topic.
d3x0r
Quote from: Khwartz on May 06, 2014, 07:32:10 PM
Hehe, yes!  The copper bar remembers me the often proved apparently and much documented overunity "Vialle Effect" ;) One even been done with ferrites around the copper bar... except in the Vialle's Autogenerator, there is a gap as the bar is cut in two equal peaces and insulated from each other.
Yes, and also the 'strange' transofrmer... which I don't find so strange... a joule thief will work with a single loop through a toroid... and it's no different than if lots of turns passed thorugh the cores... a tube is just a long toroid...
Altough; it is a stepping ... like a inchworm since more flux is available to the copper that isn't taken by the other secondary in variable portions...
and really the outside winding
but there's no current source for that light... well; there is, the original field that doesn't collapse back to the primary
... I dunno just musing
if this is version ... (14?) I'd like to know how 1-13 compared
d3x0r
Quote from: d3x0r on May 06, 2014, 07:56:34 PM
What would make it strange would be that the turn of the joule theif is actually around the toroid while the pickup is perpendicular through the core.... (I guess)
stupify12
Believe it or not. He can power the bulb most efficiently with attaching one end from any copper coil with other connection to the ground. We have found the same phenomenon on our Kapanadze coil. The bulbs or any loads like motor could be powered with only 1 end not connected, basically we called it loose magnetic coupling. Only Tesla has showed me the correct answer on this phenomenon, that video is not fake as much I have observe on my device- that is very common if you have found the Radiant Energy Phenomenon.
Quote from: Free.Energy on May 06, 2014, 10:33:21 AM
Agreed.  It does not appear to be coupled magnetically.
Khwartz
Quote from: MenofFather on May 06, 2014, 05:53:36 AM
No. One light probarly light on 0.3 of it power, other of 0.6 of it power. If two is 15 W laamps, then 15x0.3 + 15x0.6=4.5+9=11.5 W. So in is 15 W out is 11.5 W.
Lol, how can you be so precise? What about if one light probarly light on 0.4 of it power, other of 0.7 of it power. If two is 15 W lamps, then 15x0.4 + 15x0.7=6+10.5=16.5 W. So in is 15 W out is 16.5? ;) Still without a "light bulb unit" indeed powered with its nominal voltage (and frequency and wave form), how to know!
Khwartz
Quote from: stupify12 on May 06, 2014, 08:54:48 PM
Hi Stupify12. So, did you get overunity like this?
