0 Members and 81 Guests are viewing this topic.
zcsaba77
Quote from: d3x0r on June 19, 2014, 07:39:07 AM
Ruslan said that the system worked better on (17?) volts instead of 12... so the other is just another TL494 that steps up the 12 to something a little more.... He doesn't really say a lot of use... he does say that the only ground connection is on the output and that everything else is floating on its own ground.  and that the system is very hard to keep tuned that it depending on load and other factors constant adjustments have to be made...
I see, if load is stable, probably he can adjust to stable system, some components is cannot access now (KT 926), probably he used from old electronic machines, it was not mentioned instead component?
MenofFather
Not 17, but 14 volts. He say, that better power suply remake and make it for 14, not 12 volts. He say not small amout, but something important he not say. Only maybe that coxal cable must be 50 omh. Ferite ring for former nanosecond pulses minimum must be 1000 HM, but I read in Belkin book, that most best result give 3000 MH ferite ring.
If you have questions, I can try answer, because some information to me send he, then we write in PM, that he not send in forums.
Also he say, that coaxial cable must be shorted on end. And he recomendate use G4PC50U instead KT926, because KT926 max voltage is 150 volts and it risky to burn it. And amperage have higher [/size]G4PC50U, than KT926, if you chek datasheet. [/size]
stivep
yes the schematic is in the video  switching between two:
- Daly and Ruslan for comparison and showing  individual  block of Ruslan schematic.
This is link to exactly that part of video:
https://www.youtube.com/watch?v=GnE1fjVANS8#t=1122
You a the force of this movement I'm only the messenger. :)
Wesley
stivep
I have never formulated exactly my best wishes.............................It is the first time.
What are my best wishes?
I would love to  face funeral of oil-energy  industry being still alive and not imprisoned
And if that  happened I will still make  a lot of money along with anyone else in the world who instead of  buying the device decides to build it
  patent free( no licences and no restrictions other than safety)
Wesley
zcsaba77
Quote from: MenofFather on June 19, 2014, 11:43:53 AM
and what type is the ATX (what was connected after battery), and one another (maybe stupid) question, you mentined ferrite ring, its possible use instead old TV yoke ferrite core? its conical type, I still not saw how its look but I have at home 3 old CRT TV (2 is possible B/W), I havent time disassembly it
