0 Members and 224 Guests are viewing this topic.
zcsaba77
Quote from: stivep on June 20, 2014, 08:09:05 PM
http://www.tornadoacoustics.ru/_fr/1/__--__DE_199273.pdf
can anyone find English version  or German version translated of this patent?
FE Transformer  capacitive coupling
or to be more acurate with translation:
Transformer with capacitive load
additional material
http://my.mail.ru/mail/obrazovanie-new/video/3551/10085.html
http://x-faq.ru/index.php?topic=35.0
Wesley
Hi Wesley
What is between foils, somekind insulation material? or two side stick tape?
regards zcsaba77
d3x0r
Sorry I'm gonna ramble somewhat nonsensibly a bit....
The advantage of the GNSI over the Kacher is that the former is tunable in frequency... the kacher becomes a fixed point that everything else would have to conform to.  At 14V, and a few extra turns on the primary, I get the 1.5KV (and actually +/- 1.5KV rather than an impulse) that the nanopulser generates without the rare DSRD diode and fancy 3000perm core... but then it's not meant to be one pulse, but a continuous pulsing thing much like the kacher.
Also instead of the TL494 which idles at 10mA I use a royer (mazilli) ZVS.... though I wish I could remember how I kept the low half of the wave... there's a diode somewhere that helps that.
if I light 1 LED or 60 it's an additional 20mA on the system.   It, however, lacks the current to drive a power supply for the down convert... considering a stepdown transformer, but it has to be something custom, becuase off-the-shelf  transformers are tuned to 60hz... and I'm at (I dunno 10Mhz at least?) on the output coil.
I saw on the one kapanadze aquarium someone indicated one wire was a ground that went around the coil, and the other wire came from the coil... I now believe that. ...
https://www.youtube.com/watch?v=8I1NRbPl4P4 WIP (work in progress)
x_name41
additional material
Wesley
conversion of reactive into active power has in Bi-torodal transformer Thane C. Heins :)
zcsaba77
Quote from: d3x0r on June 23, 2014, 06:13:39 AM
hi d3x0r
How do you think?
regards zcsaba77
