0 Members and 175 Guests are viewing this topic.
Zeitmaschine
Two transformers and two capacitors.
In this context that makes only sense when these transformers run on two different frequencies/phases.
One frequency should be 50 Hz. What is the other? 100 Hz?
Tak  ;D
PolaczekCebulaczek
QuoteA tak swoją drogą to jak myślicie, są jakieś szanse że, ten projekt lub "clearence" zadziała ?
zadziala,ale z marnym skutkiem - probowalem, mam inwerter, prostownik, baterie i te toroidy i gowno z tego wyszlo!,grzeje sie ten caly system V na baterii spada az wszystko w koncu zdechnie,marna z tego "samozapitka" free energy =0, nawbijalem pretow w ogrodzie i nie pomoglo! lepiej popatrz na na temat Dally kapa kuzyn,chociaz podejrzewam ze te "ruslany"(tariele?) przesylaja prad przez ziemie(ewentualnie kaloryfery) z ukrytego nadajnika do dostrojonego "odbiornika" ktory namietnie nam pokazuja...,nie mniej jednak jesli tak jest to i tak jest to jakies tam odkrycie,(tesla earth transmission?)teraz probuje zrobic cos takiego.Troche rozumiem ruski.
it will work,but with little success - i tried it,i have an inverter,car battery,battery charger and toroids and shit comes out of it!the entire system is getting hot and V on battery falls down till everything goes off.it's poor "samozapitka"  free energy =0 i put many rods in garden and it didnt help! better have a look on Dally kapa cousin thread although i suspect that "ruslans"(tariels?) are transmitting current trough ground(eventually radiators) from hidden transmitter to tuned "receiver" which they are passionately showing to us... ,hawever if thats the case ,then it is some sort of discovery(tesla earth transmission?)i'm trying to replicate this now.I understand russian a litte bit.
nerdk
Ok so I've being studying the device and am planning to build or try to replicate one, my questions is on the schematics there is dd 1.3 and dd1.4 What the heck are they ?>  :o  ???
Please help   :)
Enjoykin
Logic gate NOT.
There are 6 invertor logic gates in К561ЛН2.
Analogue is CD4049A.
Look here for Russian component. Use translator !!
http://tec.org.ru/board/k561ln2/149-1-0-1418
Analyse this schematic. Here is principle. You need hit sinusoid with unipolar pulse exactly on sinusoide maximum - on peak.
Zeitmaschine
Quote from: nerdk on April 27, 2015, 01:07:57 AM
Please help   :)
Quote from: Enjoykin on April 27, 2015, 02:07:02 AM
Logic gate NOT.
Could you show me the logic gates in Stepanov's carpentry setup?
