0 Members and 180 Guests are viewing this topic.
Hoppy
Quote from: cheappower2012 on September 11, 2015, 08:02:11 AM
Your theory of it being a cable with an inside wire is a good theory,however
if you trace the circuit,it is ok as regards the ground since the ground braid is connected to the
ground to one end of the coil.One problem is you can not show a connection to the other end of the coil thru a wire,there is none.
The other problem is aking21 told you that they removed the ground cable and it still worked.Of course for your theory to be true aking21 must be a liar.
Of course since no video was filmed by the crew showing this its basically aking21's word that this did happen.
Aking21 was very honest in stating he wanted to make a little money and bring this device to the world so I believe him on this.
The team could not be so stupid as to not feel the ground wire,understandably it is very hard to believe that
a Santa clause looking guy could come up with this,where brilliant people in the world could never
come up with something like this.Both the tpu and kapanadzes device are variations of each other
I know we have had this conversation before but as I showed in my posts at the time and I proved by experiment, that a very thin teflon or other type of heat insulated wire is all that is required to run a 2KW heater. You cannot just dismiss this by looking at the thinness of a short section of flattened braided tube, especially from a very grainy video. I'm not calling a.king21 a liar, just criticising his team for showing no video evidence that they did in fact disconnect the braid to show the device continuing to operate. The team may well have failed to feel the braid, after all they traveled a long way only to fail to video capture the disconnection of the braid (assuming it was in fact disconnected), something important that would have at least quietened down the naysayers. As for where a thin 'x' wire may have exited the braid and connected to the coil in the tank, again its not possible to determine this from the poor quality video shots and the chaotic build within the tank. Sometimes the best illusions are the simplest ones. Also, as I originally pointed out, why go to the trouble in using a long length of expensive copper braid for an earth wire, when his other devices use ordinary wire, for example the device Wesley inspected on his visit to meet TK. I'm fairly sure that it was not the braid stripped from the co-ax blue inner conductor used for the coil.
I'm not saying all this as a matter of fact, just a very plausible theory that cannot be ruled out, anymore than the device can be proved genuine, with what little information we currently have available.
Hoppy
Quote from: T-1000 on September 11, 2015, 08:24:45 AM
The experiments from 2010 are described in main Kapanadze thread on pages 500-600 so it is all there..
Unfortunately its not all there. A full wiring interconnection diagram is not supplied, showing full details of power supply used and FG interconnections, test probe placements etc.
T-1000
Quote from: Hoppy on September 11, 2015, 10:09:33 AM
The Caduceus coil - http://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/7680/
Just in circuit diagram the spark gap should be flipped with capacitor in places on AV plug, it was mistake in ciruit.
The driving circuit was simple push-pull tuned to resonance...
Hoppy
Quote from: T-1000 on September 11, 2015, 10:33:00 AM
According to Wesley, the only power connection was as he posted on the Daly thread: -
"I  have witnessed 600W form few mW input.
or
from 10W total power drown from the grid by 2 identical  generators."
"- the estimated but not measured power delivered  to coil from  each of generators is less than 1W because of impedance mismatch*.
and was in region of few mW.
-the maximum halogen light bulb I have witnessed was 600W full brilliance.
- the maximum  halogen light bulb achieved but I  did not see  it  personally 1kW. (I was tired and fall asleep)"
Only one generator is shown on the very rough diagram posted. Where was the second FG connected and what model FG's were they. Can you please produce your own corrected circuit diagram, including FG earthing.
T-1000
So it was about Yoke, ok. Due 2 devices mixed into single thread it always caused confusion.
The second signal source was from 9V 1A 50Hz transfomer powered by grid 220V.
