0 Members and 131 Guests are viewing this topic.
scratchrobot
Quote from: d3x0r on October 04, 2015, 08:11:20 PM
Akula gets a radiation detector; reveals nothing more than background radiation.
https://www.youtube.com/watch?v=xVMy0-iwISM
demonstrates more radiation coming from a spark gap
https://www.youtube.com/watch?v=N0OAAAZaJ7w
Demonstrating ... load following?
https://www.youtube.com/watch?v=Oip4C0JRGOo
(using a meter that can compute watts with vols and amps input, watts grows with time)
https://www.youtube.com/watch?v=CabuXEFw4E0
He is not using nuclear power to light the leds ???
stivep
As experiment of akula with small light-bulb goes..:
I recall  conversation I have had with him  when I said that light-bulb can be ON, in presence of strong electromagnetic  field.
Even if diode is not present.  or in near field from  radio transmitter. That is pretty obvious to most of ham radio operators.
Could that  happened in Far field? Good question .
My answer is yes
However I'm kind of   thinking about it.
People have been powering their houses  out of Strong Russian Radio transmitters made to mess up with signals (transmission)  of Radio Free Europe during cold war time.
the distance was  even few km.
The bottom  line is that Akula  have really stop me there to explain to him even more.
My position is that his 1.1kw device is real as it was conformed by Tiger.
Also Tiger has got the same phenomena on his table.
the geographic location of Tiger is also in Kazakhstan  but around 450km  from Astana.
so if the device is geodependent than it would fit to the description.
but rest of what he shows, is very much in doubt.
He just want to keep the public active.
Radioactivity measurement
And possible contamination of GM with  HV.
Akula shows nothing.
He has got old Russian made Geiger–Müller tube based gamma detector.( on the board with  some internal vacuum tubes  as electronic design is dated   year  1956.Made till late 80ties in Russia.
It could detect betas as well with the  side window open.
Betas are  prime suspects in  energy conversion.
whenever you  have  gamma you have X-rays.
Photons are  so difficult to be  counted for energy conversion.
Gamma are photons
Beta are mass particles.
X-ray  are photons
In conversion of  photon into anything it is most likely that it is converted to  heat.
That is why cellphone is dangerous when close to head.
Ionizing radiation  affects DNA and RNA
and yes in did gamma  and x-ray are ionizing radiation.
There are plenty of things you guys  may not know but  generators powering satellites in  many of instances uses nuclear  fuel not
in form of rods controlling reaction.
I do not  even think that there is even one like that in space.
Well from the old old times maybe ..
These used  for the past 20 years can not blow.
Same like Thorium reactor.
And these are based on beta particles.
Well.........
not entirely
In some of concepts heat exchange is converted to electricity like  in typical sterling engine.
Some of nuclear fuel is naturally  hot.
There is however very small device the drawing of it  has been once  published by me using magnets and some of radioactive material to produce  electricity   in very direct fashion.
You just  went over with no echo on it. Like it did not exist.
Whatever,.............. does not matter.I will not beg anyone to pay attention to me.I will never gain anyone's approval by begging for it. I got pissed off .
It is going to  be out anyhow only in more convincing form.
First I need to  get hands on  LN2 generator so  I will be able to continue with Colman  by  cooling HPGe detectors  and  playing  with "frozen magnetic  flux"
Just for some of you to think about?
Suspended magnet in cryogenic temperature below 77K has mass and mass have weight.
So how much of the weight can be hold suspended?
50kg? ..........100?
Can you froze local magnetic filed orientation  and take it with you?
Is that  be like  stilling  that magnetic  field?
Hover?
Well  Lexus hoverboard works  on a bit different  principals.
something interesting  to read.http://iopscience.iop.org/article/10.1088/1742-6596/97/1/012102/pdf;jsessionid=A5B1C65575DE6C0468E5EB84851BDA24.c1
letter from my Friend Roy  the guy I respect so much:
This would appear to be very similar to an electromagnetic,
except that rather than use the simple ferromagnetic material
in which magnetic fields produce eddy currents which are dissipated as waste heat,
this device uses superconducting materials with no energy loss from resistance to eddy currents. Interesting,
but you have to factor the cost of the superconducting material and of constant refrigeration to temperatures
that the material will be always be superconducting.
1) Can you use such a device's magnetic properties to induce a magnetic field in another object?
Yeah, sure, but that can be done without the need of superconducting devices.
2) The basis for the Lexus Hover Board is already very well explained by the Meissner Effect.
As you might have noticed in Brainiac75's videos, moving a magnet towards
a good conductor produces eddy currents and opposing magnetic fields.
Superconductors are the ultimate example of this principle in action!
If you wish to dig deeper, for a more accurate discussion, superconductors in the Meissner state exhibit perfect diamagnetism,
or superdiamagnetism. Rather than repulsing magnetic fields,
they are described as expelling magnetic fields!
A thorough understanding of this requires dealing with the London equations,
which is beyond the scope of this course, but will be offered in a later graduate level course <grin>!
(The magnetic field lines are not physically "stuck" inside a superconductor- if they were, they would not possess any magnetic forces externally.
The domain orientations are the things that are "stuck", which is why their magnetic fields do not rapidly dissipate.)
Roy
Problem of many  of you is that you do not care what I write .
You just happened to chose ,  to wait for ready  answer.
for these who care?
I respect your criticism, it sometime aggravates me  however I'm happy if I got  constructive criticism.
Wesley
Hoppy
Quote from: stivep on October 20, 2015, 12:15:54 AM
My answer is yes
Wesley
https://www.youtube.com/watch?v=Xy5eDbeYwsk
magpwr
My answer is yes
Gamma are photons
X-ray  are photons
Well.........
not entirely
Hover?
for these who care?
Wesley
Dear Wesley,
Although i no longer choose to be active to contribute in this forum or the Dally's since there is nothing new for me to learn at the moment.I still do respect and read your postings.
If you need my honest opinion-Nobody is able to follow you related to Colman or some other experiment reason being none of us in here is a Phd holder or a scientist.Maybe i am wrong.
Instead of
"frozen magnetic  flux" why not try to create a "magnetic bubble" which move using little current/signal in order to create greater change in Magnetic flux like a flip flop within a magnet.
Who knows maybe the kapanadze winding in itself is the keeper for this magnetic bubble which move up and down the winding after a discharge via nanosecond HV pulse to accelerate movement.
