0 Members and 171 Guests are viewing this topic.
jbignes5
 I would like to say you are partially correct and here is a photo showing this set up in detail.
Picture 1: scematic of system start and mid section ( oil filled no core transformer).
Picture 2: The special transformer (transformer 2 from left to right) in main schematic.
Picture 3: The modified spark gap.
Picture 4: A way to use it!
Now picture 4 is a most curious design. Does that look like a single plate in the two disk system of TK's? All those pictures were from this: http://www.tfcbooks.com/tesla/1892-02-03.htm
Now I know the lecture is titled alternating current but it couldn't be further from the truth because Tesla didn't figure out that part till later that it was impulsed DC. You know how a capacitor can be step charged till it releases right? Like across a spark gap? Well this impulse will charge anything within it's sphere of influence. If the speed is sufficient enough you can energize coils very very easy with this system in a DC like manner. Maintaining any load as long as you can increase the pressure or voltage of the device and stay within the matters limit of that pressure. If you have a succession of impulses it isn't dangerous because the matter has time to charge up but impulse it once and it could go boom well the matter could go boom if you override the internal potential gradients of that matter. A single Impulse exposes the matter to too much of a charge increase and could separate the matter very easily like we do in sputtering techniques. As long as you can maintain that matter in an excited state it doesn't have to bounce all the way down shooting further into the charge within matter. Go low enough and the vacuum takes over and walla no more matter.. Well it will be in really fine particles that we could not see with the naked eye.
Oh and I might as well show the special caps Tesla was designing to handle the extreme pressures he was trying to create in as small form factor as possible (See picture 5):
Oh and this one shot of the method to shield the wires and pressurize the channels created (See picture 6):
     Figure 1 is grounded through various devices and figure two is an ungrounded shielding based on the size of the shield sections. size=period reactions to field expansion. I believe smaller sections=higher period frequencies.
Acca
 Supercharging of heavy amps, by Tesla discovered...
Tesla, however, he realized that this anomaly was hiding behind the same cause of the mysterious flares he had seen occur even during the violent energy release of its powerful electric accumulators. The researcher Peter Lindemann has indeed written: "Tesla knew that the strange supercharging effect appeared only at the moment when the dynamo was connected to power lines, as was the case for the discharge of its explosive condensator.
Momentary voltage supplied by the dynamo appeared more focused on the cable length.Tesla calculated that this electrostatic concentration was several orders of magnitude greater than any voltage of a dynamo.
Engineers of the 1890's instead of studying to understand the nature and exploit its great potential, preferred to eliminate the problem with a good grounding, as if it was just an unfortunate technical hitch fo them...
Once freed, the charge of compressed energy in the capacitor generates a violent collision against the electrical resistance of the conductor. The type of physical effect thus produced is dependent on the speed and power of impact, more or less as it is giving a slap on the water. The faster the blow inflicted on the surface of the fluid and the greater the resistance he encounters. Above a certain speed, the water assumes the consistency of a solid and develops an opposition similar to that of a concrete wall.
This hypothesis, suggests that the strong pressure exerted by the flow of electrons creates a turbulence that releases energy vacuum (reaction) a supercharged power button on the cable conductor. This would explain the instantaneous and momentary appearance of powerful electrostatic fields in large installations of the end 800 foot cable and also their manifestation in advance of the sliding of the electrons (delayed by the impact of the electrical resistance) and the current routine. Tesla concluded therefore that the electric field is not produced only by the electrons, but also by something much more subtle, able to cross any state of matter.
Tesla made the frequency of electric discharges issued by the capacitors could be manually adjusted by a simple spark gap (a kind of safety switch formed by a layer of air insulation placed between two electrodes) and the most surprising fact was the power supplied by the energy pulse produced this deadly shock.
According to research carried out in parallel by Peter Lindemann, Eric Dollard, Tesla discovered that the sequence of pulses of duration less than 0.1 milliseconds generated the following phenomena:
vaporization of  wires;
generating shock waves that invested and penetrated objects by moving them or causing them to vibrate;
cooling the temperature of the surrounding environment;  artificial brightness.
Acca.............................................................[/font]
jbignes5
I highly doubt that the picture you have shown is of an impulse of the Tesla type. But lets use your example to prove a point. What is the blue stuff it is showing? Plasma right? Well this plasma is attracted to the high voltage field. So much so it condenses and gains strength. The speed of the plasma is increased and we see light in the plasma's wake as it travels twords the high voltage source. Plasma flows like water and we could actually make an analogy to make this easier. It flows to the source like water flows and collects into streams and then into rivers. Now lets look at what happens when you pull the table cloth or medium under the plasma or your best china. Move it fast enough and the table cloth slips out underneath the china like it wasn't actually sitting on the cloth. Well impulse technology does just that. If you are seeing plasma then you are not pulling the medium fast enough. Plasma would be a waste really and Tesla said that his systems did not involve magnetics ie plasma. It pulled the medium into the source and condensed the medium to get higher in density. This increases the conductibility of the space itself and allows things in that field to have an amplified effect of energy containment and transfer. He called that his magnifying effect. If he saw magnetism he considered that a waste of energy in this technology. Now why would he say that?
I believe Tesla was onto something. What that is, is a lossless transfer of energy that can be transformed into magnetics where he wanted so very little is wasted in the load. If you have magnetics in your system and it isn't transformed at the load or the magnetic field isn't locked in a circular core then you are wasting tons of energy in the system due to the magnetic field. Hence the reason for the shielding and very high voltages up and until the load itself. The reason for using cores like that is to purify the electric field which is solely responsible for all transmissions of energy or induction through space. Left unchecked the electric field will form the magnetic spectrum and emit an effect of that spectrum.
Now for picture 1:
This is a system with a loop like TK uses. The loop is from the electric field (Field coils) transforming into the magnetic field or heavy copper Rotor coils which are being turned. The electric field converts to a heavy magnetic field which locks onto the field cores ring core. In that event the magnetic field cuts the field coils and generates more electric field which generates more magnetic field in the rotors core. All one needs to do is scoop off the extra and use it. Simple huh? Lets not mention the bifilar rediscovery that Tesla used as well.
Please don't get confused by this patent. Just below the generator title in the center of the page is a sideways view of the rotor in the upper portion of the generator with the check belt attached.
The motor is the prime mover of this system. It is connected to the rotor shaft as well as the exciter and is used to turn the rotor and exciter and is most likely using the bifilar coils to increase the magnetic fields strength in the motor.  I also believe that this setup has a controller that is not shown. This controller is most likely in between the exciter and field coils. Since most patents are basic to get the basic point across about the invention then we know have to work with this design and improve on it. The controller I am betting is the impulse circuitry which should add way more power by amplifying the energy supplied to this circuit. It could be the exciter is on a pully system via the check belt to increase the turn ratio of the high voltage generator and charge up the caps to breakdown of a magnetically controlled spark gap. With the magnets being movable to increase or decrease the impulses purity and frequency.
verpies
Quote from: macitana on December 01, 2015, 05:04:24 PM
Hi.before excuse for my poor english.I have a guestion.I sow two words in a youtube video.One of them is CW and second is CCW.What is the meaning of them.Does someone say?
CW = ClockWise
CCW = CounterClockWise
stoyan_
Hi everybody  :)!
Is it ok to ask for three questions ?
There are 3 .jpg pictures in the attachment
Each .jpg is for each question.
Is it ok  to answer if you know for sure and a some short answers like :
Question 1 : ------
Question 2 : ------
Question 3 : ------
Many thanks in advance to all of you.
Cheers and Regards.
