magpwr
Quote from: Atommix93rdAtom1 on January 03, 2016, 05:39:18 PM
My CV ? HAHAH I don't do cvs ..... I like to be a voice of inspirational logic but when meet with disrespectful nutters I tend to mirror them the best way I can hahahah
I was trained many years ago by a medical electronics company than went into construction and than into performing music ! That's my cv ..... Quantum mechanics is my speciality but with harmonics ! And I now measure the universe with only harmonics as all and everything is resonance !
The hard part in all the new energy technology is in fact the secrets of harmony and engineers or scientists who do not understand music or the laws of it will struggle to understand the new energy revolution and will have to stumble on the secrets by chance just like tesla .....
The fundamental basic to understand is the law of the fifths and what they do and why they do it ! To truly understand me you need to forget about everything for a little while and go find a good finally tuned piano ! You place my harmonic code on to the keys over one octave ... Each scale is set as one colour and for a very good reason !
When you find this piano than finally you will understand what the fifths are ! To do this you chose a key say C and C is red in the code I have given you ! C is the 1st note in C either major or minor ! Than along the scale you find the fifth note of the scale of C .
You hold down the 5th note tight and you don't play that note but than just play the 1st note which is C AND LISTEN .................
What you will find is that the 5th note that you are holding down also plays when you play the 2st note ! And all 5ths do this little bit of magic .... This means that there is an energy gain over one note and if you want to increase that you need to just keep adding 5ths ect ect  !
The planet has a key frequency and this mysterious electrical field is a 5th note scale harmonic of that frequency ! so plug in to it hahahah its that simple .....
When you are dealing with a coil say the primary coil for a kapandaze type system it has to be set up so it holds this key frequency in the coil or you will never ever be able to build your generator ..........
The coil must be the right coil and its length and tightness must be a perfected string of resonance for the field to take hold in the coil ....... Its that simple !
Its like a glove if the glove is to small for the hand it wont fit on the hand if its to big it will keep falling off ! ect ect ! There may also be some interesting problems as to your geological location and this is probably why one set up in one part of the world will not work in another part and indicates a connection of the field to gravity and the density of the resonance ect ect ,,,,
I do deals and for a good reason ! The unified field oscillator I have sent you is the only device that can convert this energy field into normal grid current and I am hoping you will do that ....
The other thing to mention as to the primary coil is you need to make sure the length of that coil fits from peak to peak of the grid supply voltage and frequency .....
I asked you for a NDA and gave you the EVP plan by email its the only government funded project in the world to day and its holding there by a tiny little thread ... Every time I try and find a small team to finish the work with they either lie or cheat and some have even resulted to holding my trade name on the internet and attempt to black mail me into giving up the final part of the data ...
How can good things come about if the road a head is paved with this kind of corruption ?
Also there are big problems with all the Russian system as re ground radiation and other RF problems and we are concerned as to the lack of health and safety that runs like a bull in a china shop over all this so called free energy technology ! Some of the secrets are best kept secret .. The last thing you want is a bunch of nutters pumping up ground radiation ,,,, It would stop people living at that location for over 30 000 years !
The grounding problem is something that can be over come and who ever does that wins the global market if they can also confirm health and safety and that will cost a bit of money !!!
I am good ACCA and to dam good to be playing around with fools ... The logic around the ground radiation problem is that all energy will flow in the direction of the river .... When you switch on the lights and your ground cable is deep and all electrons are spinning in that direction ground radiation will flow up to meet the lights ...... But for now we need to get you up and running and let you do the checks ect ect ....
But there many ways to go and I suggest one way with no ground cable but you may wish to do it all and make a decision from there ...
hi Atommix93rdAtom1,
Do you have any form of "credentials" to show us like in the form of videos to show any of your experiment in home or lab if that is permitted.
I am guessing that you are likely more older and hence should be more wiser than I am.
Since you are talking about harmonics or longitudinal wave which is subject of interest for me since 2014.
No offends but we have seen many members whom came and did created some smoke but no show to date.
Let's see what you got.
Base on latest experiment-
Do you know anything about BEMF recovery which handful of Russians are good at.
I won't bug you anymore if you got nada video to show.
Dog-One
Quote from: stivep on January 04, 2016, 12:10:12 AM
https://www.youtube.com/watch?v=260ILnIjVeA
Wesley
Thanks much again Wesley.
Just FYI,
I went through all the Vasmus videos here:
https://www.youtube.com/user/DragonsLord76/videos
And noticed the little kill wire is actually connected to a micro switch.  It just extends the mechanical lever.
magpwr
hi stivep and everyone,
Please do check out DragonLord-Vasmus creator random theories.Not for the beginners or armatures.
http://matri-x.ru/forum/index.php/blog/1-%D0%B1%D0%BB%D0%BE%D0%B3-%D0%B0%D0%B4%D0%BC%D0%B8%D0%BD%D0%B0-matri-x/
Do take note if using google translate the attached image can't be expanded.
It's wise to open 2 version of the same forum just in case.
stivep
Quote from: Atommix93rdAtom1 on January 04, 2016, 07:40:46 AM
the all text is quoted below.
QuoteAtommix93rdAtom1: sine
I have isolated coil effects that trap a charge in the coil and that is without anything else just a single coil ... And this is where I fill the starting point of this story all began many years ago and not just with tesla ...
1. There  might be energy storage in any capacitor  made from any possible material or powder or rusted  particles but capacitor is characterized by its  storage capacity.And that is directly  related to its size ( per plate of capacitor.). That is why  capacitors are made  from thin double foil divided by insulating paper and rolled  into small roll- to squeeze it to  as small as possible outside shape. If rust is used as capacitor than the rust is made out  oxide iron( most likely) porosity adds to overall outer diameter of that rusted particle but than
You are just in dead spot- particles must be able to create capacitor and capacitor is two plates oppositely charged and divided by insulator[size=78%] [/size].And that oxide is an insulator by itself
That is why ferrite  rings have so big resistance. But their overall  charge  storage capacity  is very small.
If you analyze  rust than try to find if charge in what you saw comes from its "battery like" chemical reaction or from any external charge stored in  "capacitor like" storage of it.
2.
QuoteAtommix93rdAtom1:[/size]In the video we see a small 9v battery applied for less than a second and the system starts up and the bulbs are than switched on and all the components are in view. But I was wondering why all these systems only power lights and not motors say like a 900 watt drill hahaha
That is easy. In most of  this devices guirlandes of light bulbs are connected in series  the voltage is high so lightbulbs acts as resistors  connected in series.
there is nothing steady there (not voltage nor frequency)
Electric motor has reactances  and its operation is based on its reactive nature.
Tungsten wire of lightbulb is mostly resistance.
3.
Atommix93rdAtom1:
To little information for me to  base  on. All you actually saying here that you did something  like isolating fight between  man and woman and now we need to know what method did you  use ?, what your gain ? how can you use it for yourself?
4.
Atommix93rdAtom1:The thing with resonance is the load and the field harmonic must be connected in some way ! The old mind set of force equals resistance must never be miss understood and to over come that problem we need to look closer at the hidden components like the electrons !  After all they are naturally charged by super nova and all have an anti particle like an anti electron ..
I do not even know how to start it.
-Load- is physical body dissipating  energy
-Field Harmonic- I have no  idea what you meant by that. I assume  harmonic frequencies of  some sort of field?
-hidden components like the electrons !- well electrons are not components however poetically you might call them  so.
-The old mind set of force equals resistance - [/size] ([/size]to poetical for me.)[/size]you meant that  action  equals reaction?
-After all they are naturally charged by super nova and all have an anti particle like an anti electron .. - how do you get your supernova charge, along with the electrons that should  "travel"  around  nucleus of its own atom to your whatever place of storage? placement?  this  sentence is  to convoluted for me I need  facts and factors . Please leave poetry on the side.
-I do respect everyone's freedom of expression.. I do not have time to waste applying  philosophy to the piece of wire.
-all have an anti particle like an anti electron .. - Please explain   what you trying to do with that  positron, what is next?
5.
Atommix93rdAtom1:So now we have a fuel to consider  and that makes things more realistic and the final component is the harmonics of the resonance and what effects that has to any system ..]
-Ok now you suggest that positron  or any other  antiparticle is/might  be ,  your fuel. Please tell me,  "how do you grab" it and what you going to  with it next?
-harmonics of the resonance  what  harmonics and what kind of resonance you have in mind? Please  characterize it.
6.
QuoteAtommix93rdAtom1:[/size]There is one effect that is of interest with a piano and that is the resonance of 5ths .. You just hold down a 5th note of any scale and play the first note of that scale and 2 notes will sound confirming that there has been a rise in the energy level out put ..I would strongly say this effect is also a contribution to the fuel of the system .
- whatever you say about notes it  is in physics longitudinal  mechanical wave. I have problem to understand you not in literature format of expression, but in scientific format where expression( if any) must support facts, and factors!!
I do not see fuel here, but you might  be able to   explain it to me.
7.
Atommix93rdAtom1:[/font]So now we have 3 fuel components electrons anti electrons and resonance and combined its a lot of energy !
All I see here is:
- certain matter=electrons
-certain antimatter= positrons
-word  "resonance"  ..............what resonance? resonance between what? resonance of what?
again I do not see fuel here but you might be able to explain it to me.
8.
QuoteAtommix93rdAtom1:The last part to all this is health and safety ??? ???  I have many questions about that as they never show a test measurement for RF scalar waves or micro waves coming off the lights and a possible major problem with the ground cables attracting radon from the ground if a system is left to run ect ect .....
- I'm completely lost with your possible description of " micro waves coming off lights" do not be poetical  please. In physic, microwaves have specific  properties so I need to know  what you  talking about.
-RF scalar waves once you use unknown to me format of expression  than I can even try to make sense   form  that too. Please tell me how do you understand scalar wave and what is that you are trying to do with it  next?
9.
Atommix93rdAtom1:[/font]Other things to consider is propagation of the electron field and a possible donation of the atomic covalent lattice and a possible field pulse harmonic from the quarks in all the protons ... In particle physics we consider there to be 9 quarks with 3 of them jumping in and out of the proton and we call that strangeness as it cant be isolated by a particle accelerator and only find 6 quarks in the end collisions but we know there must be 9 ...These 3 quarks may be jumping in and out of the plank level and could donate to the free electron field ???  Each proton has a confirmed 1kw of pure electrical potential so don't be so surprised when this type of technology produces large amounts of power ... But I do question why they never run a motor ??? ?? The knowledge of fifths is vital to understand how resonance can affect the gain in energy and also how high frequency can help to off set the problems of resistance in a load ... The last part to all this is health and safety ??? ???  I have many questions about that as they never show a test measurement for RF scalar waves or micro waves coming off the lights and a possible major problem with the ground cables attracting radon from the ground if a system is left to run ect ect ..... I dint want to spoil all the excitement but caution is a logical step in the right direction ! At this point in time I have 12 free energy technologies and have avoided this kind until now .... My research will be on health and safety and a conversion to normal power if possible .
With all do respect I have problem to understand your logical path.
Ok I gave up.
In my life I was dealing with people operating in different  languages and different formats , having different logics.
The last point #9 of your post has no acceptable logical continuity it is rather  bag where valuable leftovers of different animals  are thrown and mixed together.
I'm not trying to criticise  you.
You operate the language  that I can not use for any  sort of analysis at all ( as of yet)
Wesley
